Need three to eight good shielded power cables
Hope to get the job done at fifty bucks a piece average. Where should I be looking, mostly short and flexible. No used, l want to be the first to abuse them.
    tonyb Posts: 32,906
    3-8 ? Not sure whats in your system ? lol
    All the same ? What length ? Buy used and you'll get more cable for the buck. 50 clams even used isn't going to buy much.
  • BlueBirdMusic
    BlueBirdMusic Posts: 2,076
    Here is a place that is reasonable - Cullen Cable.
    http://www.cullencable.com/
    I have seen satisfied owners of his power cables here and on other blogs. I have one set of speaker cables and a Neutrik Speakon SDA cable I made using his cable. I am satisfied.
    I believe he will negotiate for a group of cables.
    Harry
    Harry / Marietta GA
  • hawk4
    hawk4 Posts: 27
    I just put an order for a few Cullen gold power cables in and Patrick is great to deal with. He will knock a few bucks off but don't think he will go that low. You can try pangea ac14se, a little over $50 depending on length on amazon, I run a couple of these and good bang for buck or signal magic power cord, again a little over 50 depending on length.
    tonyb Posts: 32,906
    Good suggestions, only a 50 isn't going to get a new Cullen power cord, and Pangea is pretty stiff and thick.
    Re-think exactly what ya need. A good PC will benefit you on source components and amps. If your willing to spend 50 on 8 of them, spend 100 on 4. Your smaller digital devices can wait.
    msg Posts: 9,434
    Bruce, I just happen to have 8 of these PS Audio ones, BNIB. $49ea if you go with package deal.
    Took this one out just to show you a photo of the shielding.
    I know that dark spot probably looks like burnt on stromboli cheese, but I assure you it's not.
  • ken brydson
    ken brydson Posts: 8,649
    msg wrote: »
    Look kinda Cheezy to me..
  • afterburnt
    afterburnt Posts: 7,892
    tonyb wrote: »
    Tony Iwas thinking amps first preamp second and transports last. The total number of cables would be determined by what I hear. 14se is what I think I saw at Audio Advisor.
  • [Deleted User]
    [Deleted User] Posts: 10,716
    You have a lot of stuff AB. Ever consider sell some of it and adding the 4-500 dollars you would have to spend on power cables and getting a statement piece?
  • sgmsmg
    sgmsmg Posts: 542
    I may have what you are looking for. What lengths do you need? Just reconfigured things so I have some extra Pangea 14SE MKII cables. 2x2m, 1x1.5m and 1x1m. Let me know if you might be interested and we can go from there. These are less than a year old and I have the original packaging.
    Pre:Bryston BP173
    Amp:Bryston 14B3
    Speakers: Golden Ear Triton Reference
    Source: Oppo UDP-205, Bryston BDA-3, Bryston BDP-3, Bryston BCD-3, Apple TV, Amazon Fire
    Cables: Wireworld Gold Eclipse 7 Speaker, Wireworld Gold Eclipse 7 XLR, AQ Diamond USB/HDMI
    Power: PS Audio P10 Regenerator, AC12, AC10 and AC5 Cables
    Display: Sony XBR65Z9F
    Pre: Anthem AVM90/JBL SDP-55
    Amps: Parasound A31, A51x2
    Speakers: Polk LSiM 707 (FL/FR), Polk LSiM706 (Center), LSiM 703 (SL/SR/SBL/SBR), Polk 900-LS (Atmos)
    Subwoofers: SVS SB16 x 4
    Source: Oppo UDP-205, Apple TV, Amazon Fire
    Cables: AQ Meteor/Rocket 88, AQ Niagara/Sky
    Power: Torus AVR20, Shunyata Denali, Shunyata Delta, Cullen, PangeaAC9SE Cables
    Display: Sony XBR85Z9G
  • sgmsmg
    sgmsmg Posts: 542
    Never mind I saw you didn't want used. My bad.
    Pre:Bryston BP173
    Amp:Bryston 14B3
  • mpitogo
    mpitogo Posts: 477
    • Living Room Music-2.0 Polk Legend L800 | McIntosh C70 | McIntosh MA5200 (Treble) | McIntosh MC452 (Bass) | Sublimeacoustic K231 Active xover | Denon DP-2500A | Denafrips Ares II | Belkin Soundform Connect | iPad Air USB to DAC
    • Media Room Ht-7.2.6/13.1 (Atmos/Auro-3D) Polk LSiM707, LSiM706c, LSiM702 F/X [x4], height LSiM703 [x6], HSU VTF-15H MK2 Dual | Marantz AV8805A | Rotel RB-1590 (L/R) | Appollon NC500 11ch | Sony UBP-X800 | AppleTV 4K | JVC RS2100 | 150” Elite Screen Acoustic Pro UHD
    • Game Room-5.1 Polk LSi25, LSiC, LSiF/X | Marantz SR7009 | AppleTV 4K | Xbox One S | Sony PS2, PS3 | Nintendo Wii | Gaming PC | Sony 75" LCD
    • Master Bedroom Music-2.0 Totem Hawk | Marantz PM-10 | Marantz SA-10 | SONY PS-HX500
    • Office-2.0 Ascend Acoustics Sierra LX, DSW microPRO3000 | Rotel RA-1570 | Marantz HD-CD1
    • Daughter's Bedroom 1-2.0 TBD Martin Logan Forte
    • Guest Room 2-2.0 Klipsch RP-600M | Martin Logan Forte
    • Guest Room 3-3.0 Martin Logan Motion 40, 50XT | Onkyo TX-SR705 | Apple TV | Samsung 55" TV
    • Guest Room 4-2.0 QAcoustics 3030i | Sansui AU-6900 | Topping DX7s | Sansui FR-1080 | TV
    • Maintenance: Pro-Ject VC-S Record Cleaning Machine
  • machone
    machone Posts: 1,474
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • afterburnt
    What should I get? Most of the spare stuff will be put back in service.
  • machone
    Here is a page from Middle Atlantic Products document about "Optimized Power Distribution and Grounding for Audio, Video and Electronic Systems".
    Their Signal Safe cords are very good at rejecting AC magnetic fields.
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • [Deleted User]
    what are your goals w/ the power cords?
    If it is "better" sound...
    if you
    "What should I get? Most of the spare stuff will be put back in service."
    o.k. then. just a thought.
  • afterburnt
    @rednedtugent of course better sound is important but the Dayens didn't come with power cords so I figured it's time to start getting some good ones.
    Most of the stuff is going to be put back in service in a few years lol but I am curious. What would be your statement piece?
  • [Deleted User]
    edited June 2017
    That is a good question.
  • lightman1
    lightman1 Posts: 10,776
    They won't make a difference, Bruce.
  • [Deleted User]
    There, it was said.
    lightman1 wrote: »
  • afterburnt
    I like to close my eyes when listening to music, with those I would have to. first for the ugly factor second for I will never have food again factor.
  • afterburnt
    Which good power cables that don't make a difference do you like. Wireworlds look very Flexible and the Pangea ones say the are for source components. I want a matched set for my monos and my pre. What power cables do you folks run and which ones do you like the best for making no difference?
  • Nightfall
    Nightfall Posts: 10,067
    edited June 2017
    I have Pangea and Wireworld and to be honest I'm not crazy about either of them but they're all entry level. The flat WW PCs do weird things because they're only flexible in 2 out of 4 directions but in those 2 directions they're maybe a bit more flexible than the Pangea.
    afterburnt wrote: »
    Village Idiot of Club Polk
  • [Deleted User]
    edited June 2017
    I don't like signal cable (thanks @voltz) or PS Audio. >:)
    Venom and Sigma from Shuntyata get good press.
  • Legender
    Legender Posts: 478
    I have found the Venom's to make a significant difference on my DAC. I just used the lower end $99 cable. A/B testing with my friends we could pick it out every time.
    Music: Oppo103 - Parasound JC2 - Parasound A21- SDA 3.1
    Theater: Denon 3808 - B&K 7500/Emotiva XPA-3- RTi12, CSi5, RTiA7x4, PSW505
    Sleeping: Marantz 70005 - Harman Kardon 2400 - SDA 2
    2 Channel: Cary 306 SACD - Canary Audio 906 - Pass Labs x250 - PS Audio Perfectwave DAC, Polk LSiM705, SVS SB13 Ultra
    Office: Dell Optiplex, Emotiva XDA-2, Adcom 5500, LSiM 703
    Spares: Yamaha CA-810; LSi 15; Kenwood Basic M2a, Yamaha M60/M80, Polk Monitor 7, SVS SB13 Ultra
  • machone
    afterburnt wrote: »
    The prices are on the first link.
    Example: IEC12x4 = four 12" long cables for $62.
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • afterburnt
    I have 3 STRATUS 7 POWER CONDITIONING CORDS! on the way for my 3 Dayens pieces (Sorry for yelling, I have been frozen since the sixties) I think they are really for source components. What do I need to use for high current stuff? Also I guess some of my junk is just 2 pole like a TV cord, what is them be called?
  • hawk4
    hawk4 Posts: 27
    Those are called c7 power cords (figure 8). Pangea makes a 14se c7 and cullen cable c7 are very good.
