There's a thing in my house
-- a new-to-me thing.
It's very, very dense.
Very.
Dense.
Here is a bottom view.
34211237723_4c0a931f26_b.jpgDSC_8306 by Mark Hardy, on Flickr
and a bottom/side view.
34858131692_94b2a5e46d_b.jpgDSC_8309 by Mark Hardy, on Flickr
Further details as events warrant.
It'll be a while -- this is a project*.
* Not a Pro-Ject (just to be clear).
    msg Posts: 9,466
    Ahhh, COME on!!!
  • kharp1
    kharp1 Posts: 3,453
  • voltz
    voltz Posts: 5,384
    DOC there is a nasty little spider near your Spider!
    mhardy6647 Posts: 33,049
    yes, the arachnid-type spider has been -- dealt with.
  • BlueFox
    BlueFox Posts: 15,251
    Doesn't look like a DAC to me. :)
    edited May 2017
    BlueFox wrote: »
    Verily.
    (I need to post an "in use" DAC photo -- it's been a little nutty 'round the ol' Hardy household latterly)
    bigger.
    and there are two of them.
    in one box.
    one very dense box.
  • [Deleted User]
    [Deleted User] Posts: 10,716
    First!
    (in line to buy the Doc Hardy speakers) :D
  • mrbiron
    mrbiron Posts: 5,711
    Hmmm...it's a speaker....screwed to a piece of pine....with a DENSE 10lb rock on it for stabilization.
    What is lemon zester!
  • BlueMDPicker
    BlueMDPicker Posts: 7,569
    Butt shakers for the front porch swing? Tractor speakers? Brown sound generator?
    nbrowser wrote: »
    Dual 12 inch coaxes in one box? Cripes...I was thinkin ten inch at most...but a dozen inches....sweet! (Apologies, I like a bit of detective work!)
    Bigger. :)
    Based on appearances, I would think this thing is brown-note-compliant.
    Oh, and mrbiron, it is (to the best of my knowledge) 100% rock free.
  • voltz
    voltz Posts: 5,384
    mrbiron wrote: »
    it not a rock on it, it is ;) a certain phono amp
    Much work remains to be done -- right now, we're looking at two beefy 15" dual VC drivers mounted in an -- interesting -- configuration in a massive MDF prototype box.
    ... but the thing certainly looks purposeful; I have to think it will be good for something, audio-wise.
  • FTGV
    FTGV Posts: 3,649
    edited June 2017
    Looks like bottom woofer is slot loaded with the floor or a bottom panel?
    The bottom woofer fires "up" into the sealed enclosure (it's back side hangs out in the breeze, as the photo shows, albeit none too clearly).
    The other woofer fires "out" of the front of the enclosure. You'll have to take my word for now; it's too danged heavy to drag out of its current (temporary) resting place :)
  • FTGV
    FTGV Posts: 3,649
    So then its push pull with bottom woofer slot loaded.Should dig deep.
