Is this acceptable to measure inductance?
pkquat
I have all the caps and resistors removed. The inductor is only attached to the board, terminal, and open wires. Will this connection throw off the reading or is it close enough within the LCR tolerance?
That should be fine for making the measurement.
Thanks.
You're welcome!
