Take a guess...
xschop
WAAAAAAAAAAAAAAAAAAAA!
Diffuser for the Stu Hegeman-designed EICO HFS-2 loudspeaker?
images from: https://www.audioasylum.com/cgi/vt.mpl?f=vintage&m=176804
un-tippable beer glass?
Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Village Idiot of Club Polk -
A binder clip that has been supersized?
- SDA 2BTL · Sonicaps · Mills resistors · RDO-198s · New gaskets · H-nuts · Erse inductors · BH5 · Dynamat
- Crossover upgrades by westmassguy
- Marantz 1504 AVR (front speaker pre-outs to Adcom 555)
- Adcom GFA-555 amp · Upgrades & speaker protection added by OldmanSRS
- Pioneer DV-610AV DVD/CD player
- SDA CRS+ · Hidden away in the closet
New Flux Capacitor?Home Theater/2 Channel:
dhsspeakerservice.com/ -
Well, Mhardy kept it in the audio realm. I'll have to rethink my beer mug design however. WMG is the inspiration.Don't take experimental gene therapies from known eugenicists.
Sorry, no innovative free-energy apparatus to report on. Just a MW side-project to my CRS project. Besides the usual power grab and sound mat addition, I clipped the extra mount tabs with some high torque diagonal cutters which did a splendid job. While doing so I thought some lightweight conical plastic stand-offs for the sound barrier/BH5 would be a nice solution for the CRS similar to what WMG posted about in his CRS build without having to add inner walls/bafles. The 5" dimension would probably be a little too long in a factory set CRS boxes...
Don't take experimental gene therapies from known eugenicists. -
The baffles were designed to mimic what we do to other SDAs/Monitors from the era, Dacron and BH5, without displacing anymore internal volume than necessary. Not sure how the cones would accomplish that.Home Theater/2 Channel:
I decided not to add extra inner baffles when they were built. 1" HDF and full billet fascia is heavy enough. The cones will displace @ 140cc ea. and the OD of the circular BH5 wont touch the passive.Don't take experimental gene therapies from known eugenicists.
I'm trying to understand what benefit there is to clipping off those tabs?Political Correctness'.........defined
President of Club Polk -
It reduces TRR (Tab Related Reflections).Mojo Audio Illuminati v3>>Quantum Byte w/LMS>>Rpi/PiCoreplayer>> Starlight 7 USB >> Mojo Audio Mystique v2 SE>>ModWright SWL 9.0 SE Signature>>Hafler DH-500 Amp+ (Musical Concepts Fully Modded)>>
1KVA Dreadnought
Marantz SA 8005
Sony PS4
"All THAT IS LOST FROM THE SOURCE IS LOST FOREVER" -
Me too! It's like taking the caps off the stems of your tires and then saying, it's more aerodynamic.
I mean they are his to do with what he pleases, but seems like a complete waste of time, or maybe I'm not understanding entirely. The drawing and his explanation (and single photo) don't match up to me.
"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Pangea AC14SE MKII | Legend L600 | BlueSound Node 3 - Tubes add soul! -
Can't claim an OCD diagnosis. A non-scientific good-old-fashioned explanation... I felt like it.
It would matter in an F1 car.... Saves a few grams wt. lol.
Science wise, doesn't the cone push and pull air molecules through the frame?
Hmmm.....it could be that they have an aerodynamic effect, directing the air flow and perhaps act as a damper for the backwards movement of the cone, kind of like an air brake, if you will.Political Correctness'.........defined
Or introducing laminar flow impedance, exacerbating air turbulence.Don't take experimental gene therapies from known eugenicists.
That's likely why they put a hole in the tab.Political Correctness'.........defined
shaking my head.....
....or the factory just wanted to confound future generations.
....or the baskets could be used for dual VC applications and rotated 90 deg.
....or positioning in the form for the stamp die....
....or.....yada yadaDon't take experimental gene therapies from known eugenicists. -
Yeah.....funny guy ol' Skip. Least I can walk without tripping over my own toes. lolHT SYSTEM-
lsi 9's -
My head hurtsHome Theater/2 Channel:
westmassguy wrote: »My head hurts
Beat me to it... -
What.......just a little audio humor.Political Correctness'.........defined
Oi! Let the man experiment.
Nobody is stopping him or telling him not to. I was seriously interested in the reasoning.Political Correctness'.........defined
I could be wrong, but I don't think he really has one.
"Because reasons" is the reason.afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
This side project is just shadowing what WMG did here. His baffles were 49 sq.in.
Mine will be 44 sq.in. but circular. Maybe more dia. if the Sonic barrier squeezes thru the MW holes without fuss....
http://forum.polkaudio.com/discussion/169838/sda-crs-crs-something-differentDon't take experimental gene therapies from known eugenicists. -
I changed the 3" dimension that matches the MW magnet base OD.... 2.125"
Cones are now only displacing 100cc of air and the Aleens is setting the polypropylene perfectly...
I'll be using 2 pieces of 1/2" thick sound foam with self-adhesive sandwiched together at the base and they wont move....
Two down, two to go....
