Bi amping
Can I use a stereo receivers A and B circuits to bi amp a Monitor 30 pair?
    F1nut Posts: 49,795
    edited April 2017
    That is not bi-amping as that requires separate amps among other things. What you are purposing would be bi-wiring. You could do the same by running two pairs of speaker cables off the A binding posts. Netting the same basic results as what you purpose is to simply replace the stock jumper plates with high quality speaker cable.
  • mrloren
    mrloren Posts: 2,454
    Yeah what F1nut said
  • Unibit
    Unibit Posts: 45
    I could not hear any benifet from bi-wire, maybe just my set up.
    tonyb Posts: 32,906
    Unibit wrote: »
    Understandable....with Monitor 30's anyway. Thing with receivers....they have one power supply, a cheap one at that, and that power can be dished out all on speaker A or speaker A+B, but it's the same amount of power. Same with a HT receiver, same power, dished out over 2 channels or up to 7 channels.
    Is there something in the sound your wanting to improve on ?
  • gp4jesus
    gp4jesus Posts: 1,969
    spazmo wrote: »
    In a word No!
    Samsung 60" UN60ES6100 LED Outlaw Audio 976 Pre/Pro Samsung BDP, Amazon Firestick, Phillips CD Changer Canare 14 ga - LCR tweeters inside*; Ctr Ch outside BJC 10 ga - LCR mids, inside* & out 8 ga Powerline: LR woofers, inside* & out *soldered LR: Tri-amped RTi A7 w/Rotels. Woofers - 980BX; Tweets & “Plugged*” Mids - 981, connected w/MP Premiere ICs Ctr Ch: Rotel RB981 -> Bi-amped CSi A6 Surrounds: Premiere ICs ->Rotel 981 -> AR 12 ga -> RTi A3. 5 Subs: Sunfire True SW Signature -> LFE & Ctr Ch; 4 Audio Pro Evidence @ the “Corners”. Power Conditioning & Distribution: 4 dedicated 20A feeds; APC H15; 5 Furman Miniport 20s *Xschop's handy work
    txcoastal1 Posts: 13,132
    gp4jesus wrote: »
    spazmo wrote: »
    In a word No!
    Jeez bro now you sound like Jesse :p:D:D:D
  • spazmo
    spazmo Posts: 21
