Looking for a cheap receiver for a shop setup
exalted512
So my birthday is coming up and I'm all out of ideas...but I do need a radio for my shop. It will be exposed to dust and temperature fluctuations similar to what you would have in a garage, but maybe a little less.
I'll probably go the DIY route for the speakers, but I'm thinking a 2.1 rig would be good for what I'm wanting. I'm not going for sound quality as it's just a work shop, but am looking for something with decent volume to be heard over fans. I don't have neighbors, so I'm not worried about it being too loud. I do want something capable of driving a small sub...
In a nutshell:
Does anyone have any recommendations? Does anyone have anything they'd part with that would fit the bill? I checked out ebay today and came across this.
What are y'alls thoughts?
http://www.ebay.com/itm/322464410938
Thanks,
-Cody
In a nutshell:
- can hold up in a garage
- has auxiliary input
- capability of being decently loud, even at the expense of SQ
- at least have the capability of having a remote
- Would like stereo capability with a subwoofer
- <$100
Thanks,
-Cody
Find a hitmaster. Plug your iPod in and you're good to go. Love mine. Volume goes to 11..
The Sherwood stereo receivers might fit the bill and retail for around $100.
+1, if you really want a receiver (i.e., a tuner and an amplifier in one box).
Those Sherwoods are... modest... but they're not junk.
If there's no need for an FM tuner, there is a plethora of little, Chinese-made "chip amp" amplifiers of various brand names that are all pretty good sounding. The really cheap ones are low powered -- but high sensitivity loudspeakers can readily make up for that! A 5 watt amplifier driving 100 dB sensitive loudspeakers has the potential to play as loud as a 500 watt amplifier driving 80 dB sensitive loudspeakers
Note that I am speaking strictly quantitatively (dB of sound pressure level out per watt in!); quality of the sound will depend steeply on the specific loudspeakers & amplifiers in question!
Here's a "good" example. Opinions on these hyper-cheap little amplifiers are... mixed, and (in fairness) some of them may exhibit some QC issues (not a big deal if purchased from a reputable seller, just a bit of a hassle to return/replace), but IMO/IME they sound -- good. Not necessarily appropriate for the current situation, but still maybe worth consideration.
https://www.parts-express.com/lepai-lp-2020ti-digital-hi-fi-audio-mini-amplifier-with-power-supply--310-3000
(a beefier power supply might be a good investment for amps like these)
Here are some better ones (FWIW):
https://www.parts-express.com/cat/home-audio-amplifiers/106?N=21771+4294967118+4294962065&Ne=10166&Nrs=collection()/record[endeca:matches(.,"P_PortalID","1")+and+endeca:matches(.,"P_Searchable","1")]&PortalID=1
A final thought -- while the "classic" Japanese (mostly) hifi components of the 1970s have become something of collectors' items (with commensurate prices), the 1980s and 1990s two-channel receivers by and large have much less collectors' cachet. This makes them much, much cheaper on the garage sale/CL circuit -- but they're, by and large, not junk -- and some are very, very good. You might be able to pick up a nice older but not "classic" amp or receiver in good working order for $50 or less (maybe much less).
Admittedly, adding a subwoofer to some of the above suggestions can't necessarily be done "elegantly", but, by and large, it can be done. Alternatively, one could use loudspeakers that don't require a subwoofer
^^^ whoa, lots of words! Sorry
I saw a lot of those too in my price range, but I was wondering at my price range, if going used would be better? Any comment on the kenwood receiver I linked to on ebay?ken brydson wrote: »Find a hitmaster. Plug your iPod in and you're good to go. Love mine. Volume goes to 11..mhardy6647 wrote: »^^^ whoa, lots of words! Sorry
This seems like it would fit the bill very well:
https://www.parts-express.com/smsl-q5-pro-stereo-amplifier-usb-optical-coaxial-dac-with-subwoofer-output-2x40w--230-210
My only complaint is that it doesn't have a built-in power source for a subwoofer, but I understand the constraints of my buget...The big plus side is that it looks like it will hold up very well against dust which is a big concern. I think that's probably my new front runner.
+1 on the Sherwoods.
Weird as I was just looking at this for the garage:
https://www.parts-express.com/lepai-lp-269fs-4x45w-mini-amplifier-with-remote-usb-mp3-media-card-fm-and-bluetooth-antenna--310-304
I mean it's in the cart! -
I have an older Pioneer Elite VSX-01 or 03 I forget what it is now but it would fit that bill nicely as you can do 2.1 or go 7.1 and make your garage fill with sound.
I actually considered uing it that way in my garage as one pair of speakers works well but a full 5 or 7 channel stereo would be so much better and fill the room much better. Lower volume more speakers better coverage and better to fight off fan noise , power tools etc.
I'd do $100 plus shipping unless you live close enough you could come get it or I could meet you somewhere.
Dan
So -- the internet is rife with kvetches about the original little Lepai that PartsExpress sold (with either the Tripath amp chip or a counterfeit version thereof -- who knows?), but I'll tell you what. The one I have is a perfectly little decent amplifier. It's especially a perfectly decent little twenty dollar amplifier.
I bought the Lepai mostly as a test amplifer for the 'shop'... but, once I was satisfied that it basically behaved itself and wouldn't immolate a pair of loudspeakers, I couldn't resist trying it on my Altec Duplexes. These are 1950s/1960s era studio monitors of no mean repute, very sensitive (ca. 102 dB per watt at 1 meter), gorgeous sounding but pretty demanding in terms of amplifier quality and performance. I usually use them with single-ended triode (vacuum tube) amps... but they sounded pretty darned good driven by the dinky little Lepai.
NakBX100running by Mark Hardy, on Flickr
Here's a test track for you to try your garage stereo with
https://youtu.be/3UV-2E8kEqg
^^^ It had to happen
heh -- that was posted on audioasylum this morning; I thought it was terrific. I am not a big heavy metal fan, but I've always liked "Iron Man".
I sent that link to my son and he said, in essence, "meh. I like Apocalyptica better."
That's a great deal I would take @mantis up on that!Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es; Squeezebox Touch with Bolder Power Supply
Bedroom 2.1Cambridge Azur 551r; Polk RT25i; ACI Titan Subwoofer -
winner winner chicken dinner! Message sent.
Thanks for all the help everyone. Now on to building a set of bookshelves.
Post your DYI's when done!
(being the noisy sort) -
rednedtugent wrote: »Post your DYI's when done!
This is the route I'll be going with. There won't be anything special about the enclosure since it's just going in the shop...just plain ol' MDF in a .34ft^3 ported enclosure.
https://www.parts-express.com/dayton-audio-xo2w-2k-2-way-speaker-crossover-2000-hz--260-140
https://www.parts-express.com/dayton-audio-dc160-8-6-1-2-classic-woofer--295-305
https://www.parts-express.com/dayton-audio-dc28fs-8-1-1-8-silk-dome-shielded-tweeter--275-075Music is like candy, you have to get rid of the rappers to enjoy it -
Nice.
I'm going FrankenAltec886a's for the garage rig.
Wonder if the Parts express sale is still on? Still
have the amp in the cart... -
I built a set of these for my shop. They sound suprisingly good.
http://www.mavin.com/store.php/audio/8-ohms-8-inch-2-way-speaker-kit-pair-125-wattsIf you can't hear a difference, don't waste your money. -
Nice! 8" woofs
