Best placement for subwoofer
I just purchased and installed the MagniFi sound bar. Where is the recommended location for placing the subwoofer? (I'm torn between putting it underneath the TV facing the same direction as the soundbar... or... placing it across the room (the opposite side) directly facing the soundbar.
