CS2 series 2 center channel
Hello,
I am looking for the crossover schematic for a Polk CS2 series 2 center channel. Looking to do a capacitor and resistor upgrade. I am having a hard time finding much info on his one. Any help or info would be greatly appreciated.
Thank you
  • splatee
    Went ahead and looked at the crossover and it has a 5.7ohm 5w resistor. Doing a search for Mills and Mundorf resistors they have only a 5.6ohm. Would using a 5.6ohm cause a difference?
    Thank you
  • skrol
    skrol Posts: 3,338
    Shouldn't be an issue. Figure the original 5.7ohm is likely 10% tolerance it could be between 5.13 and 6.27ohms. The Mills and Mundorf are probably 1%.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • splatee
    skrol wrote: »
    Sounds good. Thank you for the info. I am going to recap it with Clarity ESA caps and Mundorf resistor.
  • cascius
    cascius Posts: 175
    Let us know how your project turns out. I have that center and wouldn't mind having fun upgrading it. :)
    Main System:
    Front: SDA 2ATLs
    Center: CS2
    Surround: M40s
    Sub: PSW505
    Receiver: Pioneer VSX-1121k
    Amp: Carver AV 705x
    TV: Samsung LN52A650
    Media Player: Chromecast/Boxee Box
    BD Player: Sony BDP-S470
    Consoles: Xbox360, Wii U
    pitdogg2 Posts: 24,577
    go up in wattage 5watt to 10 or 12 watt no issues just extra ins.
