Picked up a pair of SRS 3.1 TL's
kjack48230
I've been looking for a pair of big boys for a while and finally bagged them this past Tuesday. Had to drive over 200 miles to get them and thankfully the were able to fit inside my car. Got them for $500 but they looked in very good shapenough. Brought them home and tossed them into my heated garage.
Last night I started with one and tore it down to begin the mod process. All the drivers look in good shape but there were a lot of snags on the fabric. I like working with wood so the idea of doing a total refacing of the cabinets was a no-brainer. Removed the side wood trim and cloth covered side panels, not to anyone who want to try this, they're glued on and you need to be careful not to gouge out too much of the base cabinet in the process of removing all the glue.
In the process I was feeling erregularities in the surface of the bottom plate, upon closer inspection of the board there was swelling, most definitely some water damage. Since I've started I might as well do this right so my nest step will require removal of the bottom plate, very carefully so I don't damage the sides of the main cabinet. This gives me the great opportunity to do some really cool cabinet mods! Bubinga has always been a favorite of mine, although Birdseye Maple is absolutely spectacular! I'll have to strip the veneer off the top plate as well. I'll post pictures of my process so anyone who likes to watch me make a fool of myself bitting off more than I can chew can laugh as I go through this project.
Of course that is just the cabinets, I'll be falling helplessly down the wormhole of internal mods as well, including a complete Xover rebuild, a total rewiring to all drivers, and of course tweeter replacement. This of course isn't something that is going to happen quickly so please be patient. I do have a full time job and enough honey do's to employ a battalion. But I promise this is going to be awesome when it's done!
Before pictures!
Nice acquisition! Looking forward to the results.SDA SRS 2.3TL's
SDA 2B TL's -
I'm unclear if you plan on replacing the side panels with all wood. If so, I'll mention that I have yet to see that ever come out looking right. Just something to consider.Political Correctness'.........defined
President of Club Polk -
I have the same ones that I'm upgrading as well (*although I doubt what I am doing will compare to redoing the cabinets.As all I'm doing is reglueing*)
Have a look at my upgrade thread and feel free to post there if you like.
http://forum.polkaudio.com/discussion/176194/sda-upgrade-thread-2/p1 -
Congrats on your 3.1's, they are an exceptional speaker! Be careful when removing the top or bottom caps, they are actually a part of the cabinet, unlike the larger, older SDA's.
They can be a b*tch to remove and will take some time to fabricate replacements. -
Mike Reeter wrote: »Congrats on your 3.1's, they are an exceptional speaker! Be careful when removing the top or bottom caps, they are actually a part of the cabinet, unlike the larger, older SDA's.
Yes, I know it will be a chore. I'm planning on just replacing the bottom since it was the only piece that had the water damage. -
After reading your post it got me thinking. The esthetic's need to follow the original design so where the black cloth panels were I'll replace with a very dark wood and the top, bottom and back pieces will be light wood. I think that should work! -
Congrats, sounds like fun! Looking forward to following your progress. I'm sure any nice wood you use will look better than the original oak ... blah!my 3.1TLs
I will fix your shifted magnets for free. -
The cabinet with all the components removed and the side panels stripped off.
The last two show the water damage and why I'll need to replace it. -
Are you talking about the end caps or side strips?Political Correctness'.........defined
All of the pieces are either veneer or cloth covered, except for the two long pieces that run along the sides towards the back.
Right, so the strips are laminate.Political Correctness'.........defined
Actually the two straps are real wood (pine and stained).
Quick question, has anyone ever used Moho Mat? Got a sheet of it for $10 at a car stereo place locally. They claim it's as good as Dynamat.
Doing a quick comparison between the two, the only real difference is the thickness, Dynamat at 0.067 inches and Mojo mat at 0.078 inches.
Good luck!
Hey, those look familiar! -
"finally bagged them this past Tuesday."
I bagged to bears in once.
I bagged them to leave but the stayed around all day!
Bird's eye maple always looks incredible. Even better with fiddleback cross waving and about six inches looking of clear over it.
My end caps and cabinets were really banged up so I did this. A lot of work but I am happy with the final result.
Nice job,I am impressed!
Looking good!!Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
WOW!! Those look great!!!
Beautiful! Do I see Outriggers on these Beauties?
Your the man!!!Some final words,
"If you keep banging your head against the wall,
you're going to have headaches."
Warren
