Door tweeters, should I care to add them?
My car has door tweeters. I will be installing MM651's. Will it be a waste of money to place tweeters on the front doors as well? If yes/no, then why? Break it down for me.
Answers
  • afterburntafterburnt Posts: 3,444
    I really don't like the speakers all over the place like in my MB (Harmon Kardon) and now my VW. Although the MB system sounded way better than the VW (Fender, panasonic). The sound coming from all kind of places sucks to me. If I had two or four speaker system in any car I think it would be better but I don't screw with the factory stuff, now if I had a 65 GTO that may be something else.
    Parlor: Yamaha RX-A2030*Parasound Halo P5*Parasound Halo A-31*Parasound 2250v2*Emotiva XPA-200 Gen1*LSiM707 Fronts*LSiM706c Center*LSiM702f/x Surrounds*Monitor70 Series II Rears*Monitor40 Series II Presence*SVS PB2000 Sub X2*OPPO BDP-103D*Sony PS3*Samsung BD-H5900 3D Blu-Ray*Samsung-55" LED 1080p Smart 3D HDTV UN55H7150AFXZA*TEAC TN-300*Wireworld Solstice cables*Blue Jeans Cable LC-1's IC's*
    Dungeon: Auralic Aries Mini*Dayens Ampino Preamp*Dayens Ampino Monoblocks*Usher N-6361*Wireworld Oasis cables*Wireworld Oasis IC's*IFI nano IDSD* Cambridge CXU*
    Panamax MR5100*Panamax M8-AV-PRO*Furman PST-2+6
    Head gear: Sennheiser HD 558*Audio-Technica ATH-M40x*Sennheiser HD 598 Cs*Audio-Technica ATH-MSR7*Philips SHP9500S*
    Hello Kitty boombox
    Spares: Yamaha RX-A1040*Emotiva XPA-1L Gen2 X2*Emotiva XPA-3 Gen2*CSiA6 Center*Monitor40 Series II*SVS PB1000 Sub*Sony BDPS6500 Blu-ray player*POS 37" LCD*Douglas Connection Furez 12 AWG 2 Conductor*Blue Jeans Cable LC-1's IC's*
    Self Control is over rated.
  • afterburnt wrote: »
    None of this made sense to me except for you thinking the sound coming from all places sucks for you. What I am trying to figure out is will my sound quality suffer if I have these stock tweeters alongside the silk dome tweeters.
    I don't think that separate tweeters etc. place all about the cabin sound good. You may like it.
    Hello Kitty boombox
  • i would get rid of the stock tweeters and go with the new higher rated tweeters
  • Replace the tweeters. Do not run the stock tweeters if you have the new ones that come with drivers. The efficiency is probably different so you may not hear the stock ones at all. Keep it simple.
    Polk S10, S8, S4
    Polk RT8
    Polk Monitor 7s
    Working on getting SDAs
  • RicardoRicardo Posts: 10,480
    Component systems when installed correctly will give you the best sound. Period.
    SOPA
Howdy, Stranger!
