Polk Magnifi Sound Bar suddenly stopped working
New polk magnifi soundbar won't respond to anything. Hit mute button this morning and all lights went out on front. Green light still on in back, woofer also lit up and green. Pressed all inputs, power on and off, etc. several times and no response from soundbar. Any ideas??!!
0
Welcome to Polk's forum, sorry you're having a problem. I believe the only thing you can try is to after switching off the AC power selectors on the soundbar and the subwoofer, then unplug the power supplies for both. Wait a few minutes then re-plug the power supplies and switch the AC selectors on. Hopefully this will get everything working again.
If not, telephone Polk's CS department at: 1-800-377-7655 select option 1, they should be there this weekend.
Regards, Ken
— Christopher Hitchens
