PSW10 setup with Sony STR-DH-550
nlorant
I bought a PSW10 to pair with T15 bookshelf speakers and a sony receiver. I'm trying to use the option one setup (receiver out to line in) and the sub isn't producing sound. I've set the bookshelf speakers to small and I have the speaker pattern to 2/0.1. I'm new to home theater setups so any help would be appreciated. Thanks
Hello,
Welcome to Polk's forum. One way to check to see if the sub is working is to turn the sub's volume all the way down on the subwoofer. Then remove the sub-cable from the receiver and connect it to either the right or left audio output of a CD/DVD player. Then begin playing a CD and slowly turn up the volume on the subwoofer, there should be plenty of bass at a fairly low volume setting.
Regards, Ken -
Tried it. Sub wass DOA. Thanks anyways
