New sub set up question.
VoodooGTS
Hello,
New to this forum and somewhat new to home theater set up. I have so many question but lets start off by one.
I have a Yamaha RX-A760BL and have a Polk PSW505 hooked up including some some Harman Kardon surround sound speakers (Temporary, Plan on going all out Polk)
My question is that when I run the YPAO configuration I notice the results of the subwoofer is -10. Is that correct? The setting on the actual subwoofer is Low Pass = 120hz (Recommended by Yamaha) and the volume is set in the middle.
Any thoughts?
Any thoughts?
No. The -10 reading means YPAO can't really set your sub correctly. Turn the volume down a little and rerun YPAO. Try about 1/3, and see if it gets closer to zero.
