DB poweramp
erniejade
In ripping CDs with dub poweramp, any advantage with ripping at 24 bit? Would it make it sound better? From what I'm readin some say yes. Some say no difference. Any experience on this one?
Files will also take up more space. IMO, files that originate as 24-bit 192 khz do sound better. However if the 24 bit file was downsampled to 16 bits, the other 8 bits of data are gone forever. When you take that 16-bit, 44.1 khz file and change it to 24-bit, 192 khz, the new file must be upsampled as it gets larger, so something is added.
As I have said before, upsampling can sound better but IME it depends on gear used and what SQ you like. I just rip redbook at 16 bit. Many DAC's upsample anyway, so IMO best to do it once only.
Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
Thanks I will continue at 16 bit.Klipsch The Nines, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's.
