B&W DM4
I'm assuming these are about the smallest of these made?
I did some digging on them and found hardly anything.
Now for the bonehead question of the day, how do these wire up?
Fronts.
Screws holding in the drivers were not tight...
Banana plugs.. Time to call it a night...
Up and running, cabinet fill started coming out the ports a bit when I stretched their legs a smidge..Sound ok...
To keep with the tradition of being a bonehead when it comes audio stuff.
Does anybody know what the grey plugs in pics 1 & 2 are for? -
Finally got a manual, gray plugs still no clue.
Sound is very nice, put them on some stands at 28.5", tried different receivers, finally settled on an old SA200 at a whopping 25wpc and I'm quite impressed at these old puppies.
Threw in an old powered polk sub to the setup and I, including the wife was impressed.
Pushed it to 3.5 on the volume, it sounded very, very warm, the highs were not harsh, not fatiguing nor was the bass "what I call, kind of muddy".
Best 25 wpc fun I've had in a time... -
Sounds good. Enjoy!2-channelBelles 22A Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
Better use this thread.
Once again, THANKS Mr Hardy!! -
I got a call in to B&W Dave to ask on the grey plugs. yep as you said nothing in the manual what so ever on their use.
I will give you 4 dollars for them as they stand, without knowing a THING about what those plugs are for"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
I gotta have at least 5...
Thanks, Hardy chimed in, I sent an email with a pic myself. -
seen it Dave thanks
I will give you 5.01 because I'm feeling generous....."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
Mystery solved.
Ken from Bowers & Wilkins stated "the gray plug in the picture is actually a Din speaker connector, which is an alternate method of wiring the speakers-not commonly used these days"
Mr. Hardy was spot on, once again!! -
Didn't B&O use a funky din on their speakers?Musical Fidelity Tri-Vista 300, Audioquest Thunderbird Zero Speaker Cable, Tyler Highland H2, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's.
