Wire connection for Atrium 5 speakers
CharlieD
Hello all,
I just installed a pair of Atrium 5 speakers outdoors. They are fairly well protected from weather. I wanted to use banana plugs at the mounting posts for easy connection but none that I have tried will fit. The connection opening is fine but because of the slight angle of the posts there just isn't enough room for a standard size banana plug. I even overpaid for a small set of Monster plugs but they didn't fit either. Does anyone make an offset type banana plug? Any other type of connectors that will work?
Post edited by CharlieD on
I don't know if the speakers will accommodate them but you've definitely given me some new ideas!
I have the same problem here in the year 2016! The best I found were the Monoprice ones. The body of the banana plug doesn't fit inside the cutout in the speaker, but I can insert the whole tip into the binding post. They are skinny enough to just squeeze in there. It would be nice to find a shorter banana plug that would fit inside of the cutout, but these are working so far.
