Armaflex strip length
zplyonz
Hello All,
As soon as the R0198-1 tweeters from Polk show up I am going to begin taking apart my new (to me) 2.3tl's. If the gaskets are anything like the ones in my old SDA 1-Cs they will need replacing.
I know I need to trim my 2" wide Armaflex to a half inch wide... but I think it would go easier if I could start by cutting the wide tape to around the right length to go around an MW6510. My maths say around 20" long per driver should be ample, and provide for fine trimming during installation... anyone with direct experience have an suggestion?
Measure twice, cut once.
2 channel: Anthem 225 Integrated amp; Parasound Ztuner; TechnicsTT SL1350; Vincent PHO-8 phono pre; Marantz CD6005 spinner; Polk SDA2BTL's; LAT International speaker cables, ZU Mission IC's and power cables all into a PS Audio Dectet Power center.
Other; M10 series II, M7C's, Hafler XL600 amp, RB-980BX, Parasound HCA-1500 amp , P5 preamp, all in storage. All vintage Polk have had crossover rebuilds and tweeter upgrades.
The best way to predict the future is to invent it.
It is imperative that we recognize that an opinion is not a fact.
Imagine making politics your entire personality. -
Hello All,
If you mean compressed, well they are supposed to be.
President of Club Polk -
Hello All,
And @F1nut is correct, the stock gaskets are very thin, and should've only needed replacement if they were damaged.So, are you willing to put forth a little effort or are you happy sitting in your skeptical poo pile?
http://audiomilitia.proboards.com/ -
Cut a 1/2" strip longer than needed. Test the length and cut off the excess.Mojo Audio Illuminati v3>>Quantum Byte w/LMS>>Rpi/PiCoreplayer>> Starlight 7 USB >> Mojo Audio Mystique v2 SE>>ModWright SWL 9.0 SE Signature>>Hafler DH-500 Amp+ (Musical Concepts Fully Modded)>>
1KVA Dreadnought
Marantz SA 8005
Sony PS4
