Polk Vintage Products Info Page???
Inspector 24Inspector 24 Posts: 1,060
edited March 2016 in Vintage Speakers
Where did it go? I can't find it anywhere on the main site at Polkaudio.com. Nor can google it seems... Is it gone?
I truly hope not, the wealth of information all in one spot was awesome and very handy. So, anybody know where they're hiding it?
Down
RTiA9 - CSiA6 - FXiA6 - Dual HSU VTF-15H Mk2
Sim2 D60 - Dragonfly 106" Panny 500
Up
LSi15 LSiC - RX-V3000
Post edited by PolkTeam on
  • tonybtonyb Posts: 29,089
    edited November 2014
    as far as I can tell, it's gone....and on purpose. However we do have the "vintage" section on the main page of the forum if you scroll down.
    Tad 803 bookies
    Polk 500 surrounds
    Polk s35 center
    Sonos
    Music-
    Joule la-100 pre
    B&k 1403 amp
    Cary xciter dac
    Cullen modded Sonos
    ERA D5 bookies
    Analysis plus crystal oval ic's
  • 5.1 System:
    Sharp Aquos 37" LCD
    Front: SRS-3.1TL
    Center: CS400i
    Surround: Monitor 10B
    PSW10 subwoofer
    Onkyo PR-SC886P Pre/Pro
    NAD T955 5 channel power amplifier
    Technics SL-1710 MK2 turntable
    Audio-Technica AT14Sa cartridge
    NAD 106 pre-amp
    Oppo BDP-103 Blu-Ray
    2014 MacBook Pro 2.8 GHz
    2.0 Office System:
    Monitor 10A (Peerless)
    Outlaw 1050 receiver
    Parasound HCA-1000A power amp
    MacPro
  • Jim, that's awesome! Thank You!
    TonyB, why would they do it on purpose??
    Down
    Up
  • cnhcnh Posts: 13,310
    And yet ONE MORE TIME (perhaps the fourth or fifth time), I ask: WHY ISN'T THIS A STICKY YET?
    cnh
  • KennethSwaugerKennethSwauger Moderator Posts: 6,407
    In the future just send me a message asking me to make something an "announcement". If it seems fitting, I will.
    "And the house you live in will never fall down
    If you pity the stranger who stands at your gate" G.Lightfoot
  • Sorry, didn't realize this had been answered somewhere else, haven't been on much since the big forum change. Thank you for the responses.
    Down
    Up
  • So any word on why the vintage products info page was axed??
    Down
    Up
  • Hello. Hope to get some opinions. I apologize upfront for my ignorance in your arena. I have two options to power a pair of sda srs 1.2. Nad 2600a bridged on each speaker or a MC7106. Would also like advice on what would be a good center channel for these. Thx in advance for advice and opinions. Vern
    Hello Vern,
    Welcome to Polk's forum. I'm afraid that when a two channel amplifier is placed in a bridged mode it is no longer compatible with a common ground speaker connection. You could use the amplifiers in a non-bridged two channel mode with no problem. If your second amplifier is a McIntosh MC7106 then I would imagine using two of those six channels would work fine. This is assuming the amp is compatible with a common ground speaker system (check with McIntosh to be sure).
    Regards, Ken
  • Thx Ken. I have the different cables that go in between the speakers one says for common ground and the other for not. I'm really unsure but my reading tells me I can bridge if I use the correct cable in between. Thx. Vern
    Hi Vern,
    You are correct, with the non-common ground cable you can use bridged amplifier.
    Cheers, Ken
  • NightfallNightfall Posts: 7,460
    I think you're talking about AI-1 or Dreadnaught? You have one of those?
    afterburnt wrote: »
  • pitdogg2pitdogg2 Posts: 9,851
    most bridged amps do not like a 4ohm load beware.....A1, dreadnaught or not..even though the 1.2 is 6 ohm rated I thinking it will and does go down to 4ohm and below...
  • I do have the AI-1 cable. So I should stay away from bridging my amps with these speakers?
  • In the distant past I have bridged my adcom 555II amps using the AI=1 with the 3.1TL's. Did not have any issues but also did not determine any discernible difference. maybe a little more clarity at very low levels. So I went back to the same ol, same ol. Held on to the AI-1 just in case I may want to do it again in the future.
    Polk 3.1TL (Gimpods boards, Sonicaps, Mills Res., Dynamat, Sonic Barrier, Hurricane Nuts, Cabinet sealing, Glue of magnets,Cardas Binding Post upgrades) - to be relegated to my daughters system eventually as I permit or am ready to part with.
    Polk CS350 Center
    Polk FX500 Surround
    Definitive Powerfield Subwoofer
    B&W 803D2
    Krell Showcase Processor
    Krell KAV 3250 Amp
    Adcom 555II Amp
    Adcom 555II Amp
    Musical Fidelity A3CD
    Sony PS4300 Turntable
    Rotel RQ970BX Phono Preamp
    Adcom Ace-515 Line Conditioner
    Richard Grays Power Company Line Conditioner (2)
    Hitachi 60" Ultravision TV
    Oppo BDP-103 Blue Ray
Howdy, Stranger!
