Help identifying resistor.
Can someone help identify these:
Look like resistors to me but not sure if the values, 1 watt is easy but what is 150j?
Trying to repair my old Yamaha AVR I found bad solder joints and a burned resistor, thread here: http://forum.polkaudio.com/discussion/168638/halp-yammy-rx-v3000-clicks-off-immediately#latest
Thanks!!!
Down
RTiA9 - CSiA6 - FXiA6 - Dual HSU VTF-15H Mk2
Sim2 D60 - Dragonfly 106" Panny 500
Up
LSi15 LSiC - RX-V3000
Answers
  • gimpodgimpod Posts: 1,739
    With that green end it doesn't look like any resistor I've ever seen, could it be some kind of a thermistor ?
    You really need the schematics and parts list to be sure.
    "If you design software that any moron can use only morons will use it." JMO
    Unfortunately for most of us we only get to experience the first day and then we can't even remember it.
    "Close only counts in Horseshoes, Hand Grenades and Thermonuclear Weapons."
    "50% Why... That's almost half."
    "I know, I'm sick and need help."
    www.gimpod.com
    "The best way to enjoy digital music reproduction is to never listen to good analogue reproduction." ~ Kenneth Swauger
  • Agree, do small ceramic capacitors get made like this? Googling tells me an upper case J denotes Joules...and 150 Joules equals 1 watt/second....But that may mean nothing....I did buy some 1w 150ohm resistors ****-u-me-ing that might be it, but I really don't want to blow it up by guessing.
    Know of a source for the schematics/parts list?
    Or if anybody knows what this little guy is and where to get more?
    Down
    Up
    Here's a link to the service manual. Looks complete.
    go-gddq.com/upload/2010-01/10010611523232.pdf
    www.gimpod.com
  • KennethSwaugerKennethSwauger Moderator Posts: 6,404
    That is probably a 1W metal film or metal oxide resistor, what is the part number on the circuit board?
    "And the house you live in will never fall down
    If you pity the stranger who stands at your gate" G.Lightfoot
  • Oh you are good Gimpod...my google powers need work, I just kept finding regular manuals.
    I'll take a look at it close tonight.
    Down
    Up
  • OldmanSRSOldmanSRS Posts: 442
    edited February 2016
    Nevermind. I thought it looked like a custom 105J cap rated at either .15 uF or 15 pF. Looking at the your photo of the power supply, it looks like a power resistor, perhaps 150 0hm?
    '65 427 Shelby AC Cobra
    '72 Triumph TR-6
    __________________
    '88 Polk SDA SRS 1.2, with upgraded XO caps and Erse SDA inductors
    '86 Polk SDA CRS+
    '84 Polk Monitor 10A (Peerless tweeters)
    '05 HSU VTF-3 Sub
    '93 Carver TFM-35 (just because)
    '88 Carver M-1.0t (just because)
    '14 PGA2310 based custom remote volume control
    '88 Adcom GFP-555
    '88 Adcom GFA-555 (upgraded/restored)
    '05 Onkyo DV-555 media
    '89 Pioneer Laser Disc media
    '89 Sony SuperBeta HiFi media
  • F1nutF1nut Posts: 39,622
    what is 150j?
    Letters are used to indicate the tolerance. J would be +/- 5%.
    I agee with Ken that it's a metal film or metal oxide resistor. So, you need to replace with the same type. The value would be 1 watt, 150 ohm 5% tolerance.
  • Awesome. Progress. I'm up skiing all day, hopefully have time to check those schematics tonight. And I'll post pics of the resistors I got, hopefully they're the correct ones. :#
    Down
    Up
  • Ok here's what I got:
    Down
    Up
  • Inspector 24Inspector 24 Posts: 1,060
    From the service manual, they are R404, R405, R413, which are apparently 15ohm 1w Metal Oxide Resistors...So I'll be making another trip to the store...Everybody agree here?
    Down
    Up
  • bikerboybikerboy Posts: 1,136
    Since you pulled 4 of them, measure them. Some should be close to what you think the schematic states..
    D:Sonore UltraRendu usb w/LPS-1->Amanero I2S converter ->I2S->TPA Buffalo 9028 w Mercury output dac w Salas ps->BAT VK-51SE w/BP Preamp via XLR to BAT VK-200-> Polk LSiM 703
    A:Dynavector DV-10x5-> Nothingham Spacedeck-> TPA Retro via XLR to Relaixed2;
    V:Vinyl rips-> ESI [email protected]/192
    SACD: Denon 3910
    Finally getting back to this, they were in fact 15ohm, grabbed some new ones and went to it. Quite a bit larger than the factory parts which I'm fine with...took just an ounce of creativity to fit them in the same space and the foil on the PCB had dela
    minated requiring a little point to point wiring.
    Also took the opportunity to clean up the volume pot so it works again and repair a bunch of other poor looking solder joints including a bunch on the display, bringing all the dead pixels back to life.
    Glad to have it back. I prefer the the sound of the LSi's on this amp over the stand in Marantz SR7001.
    Thanks for the help everybody!
    Down
    Up
Howdy, Stranger!
