THe Official "Larry's Rings" waiting list
1234568»
  • Huh What?
    In hopes of a new run, I would love a complete set for a pair of 2.3 TLs, please and thank you.
    Home Theater - Talon Firebird (Fronts), Talon Raven 2002 (Surrounds), Talon Cinema Hawk (Ctr), Talon Falcon (Back Surrounds), JL Audio Fathom F112 Sub
    Pre/Pro - Classe SSP-800
    Amps - Sim Audio Moon Titan 5 channel, Modwright KWH 225i
    Blu-Ray - Oppo UDP-203
    Projector - Epson PowerLite Home Cinema 5040UB
    Screen - Silver Tickets MPT 110"
    Primary 2 Channel - Talon Firebirds
    Modwright KWH 225i Integrated Amp
    Oppo BDP-103, Audio Research DAC 8
    Secondary 2 Channel - Polk SDA 2B
    NAD T775, Denon 2900 DVD-A/SACD
  • indyhawg
    indyhawg Posts: 1,637
    DaveMuell wrote: »
    If I'm not already in for a set for my 3.1's, put me down for complete with tweeters.
    I am in for a set for my 3.1's also whenever you do another run.
  • sfosselman
    I would love a full set of these legendary rings for my 1C's if they are available
    Polk SDA 1C Upgraded, Eastern Electric Minimax Supreme DAC, Parasound HCA 1200ii, Belles 21a Preamp, Rotel RSX-1056, Matricom G Box Q, Blue Jean & Signal Cable interconnects, Sonographe SG-3 TT, Panamax M4300-PM
  • Moose68Bash
    Moose68Bash Posts: 3,842
    sfosselman wrote: »
    @sfosselman,
    You are on the right track. Keep on keeping' on!
    I assume you have the SDA interconnect cable for your 1Cs.
    Have you read about the Dreadnought yet? A Dreadnought (or sometimes, "Dreadnaught") improves sound, even if you are using a common-ground amp.
  • sfosselman
    I am sad to say I do not have the interconnect cable with the 1C's. Right now I am using 16 gauge speaker wire and the effect is there. I was going to purchase or DIY the cable but now I might wait and replace the posts and use a custom Speakon interconnect. Any thoughts?
  • Moose68Bash
    @sfosselman,
    My advice is to go beyond building a custom SDA interconnect with Speak-on connectors. Go all the way and build a Dreadnought interconnect with a good-sized toroidal transformer.
    There are a number of threads on the Forum about building a Dreadnought to replace or serve as the SDA interconnect. DarqueKnight, I believe is the "father of the Dreadnought."
    In fact, I found my way to this Forum because I tried to use a pair of mono blocks with my SDA SRS1.2s, only to learn (rather rudely, I might say) that you cannot use the standard interconnect with amplifiers that are non-common ground.
    Then, having built one for my SRSs, I read about better ones on this Forum, and I upgraded the one for the SRSs and began using the smaller one for my 1Cs. The amp with my 1Cs did not require an isolation transformer because it is a common-ground amp. But the Dreadnought improved the sound greatly. Now, I have also upgraded the Dreadnought for the 1Cs.
    It's a mod that is definitely worth the effort.
    Larry (of "Larry's Rings" fame) also builds great boxes for the toroidal transformer used in the Dreadnought.
  • sfosselman
    I will definitely look into the Dreadnought upgrade for my 1C' . Thanks for the insight!
  • bassfann
    bassfann Posts: 151
    I need rings for 2.3's.
  • User1
    User1 Posts: 40
    What are "Larry's rings"? It sounds like I could use some as I LOVE my SDA'S!
  • cood
    cood Posts: 2
    Any chance that Larry is still making these rings? I’m in for a set for my 7B’s if he is!
  • BlueBirdMusic
    History repeats itself!
    Harry / Marietta GA
  • ptrooper
    ptrooper Posts: 501
    They certainly move things to the next level!
  • xsmi
    xsmi Posts: 1,786
    Larry, I know this is an old thread, but if you ever make another run, I'm in for SDA-SRS's.
    2-channelBelles 22A Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
  • windstriker
    Ug I saw this thread pop up and started to get excited..... O well
    pitdogg2 Posts: 24,559
    use hurricane nuts. you're more than likely to win the lottery before Larry makes more.
  • windstriker
    Ya i know doesn't mean i cant hope. Im already using h nut but would upgrade if given a chance.
  • nancyisthebesttony
    Hi there all polkies, I have owned polka 1.2 TL for many years with some mods done. I need to still do Larry's rings as well as crossovers so I also need new upgraded boards. I don't know if these are still available, and if so then by whom? If anyone can help a old polkie with most mods done would most appreciate yall. I live in BC Canada so parts arrive slowly 😭 but polks make me feel better quickly.
    F1nut Posts: 49,794
    Larry is not making rings. Use Hurricane nuts instead.
    Member westmassguy is selling the Gimpod SDA boards.
    Thank-you so kindly.
    Tm
  • ptrooper
    ptrooper Posts: 501
    Larry would have the programme to make them ! Maybe someone could take over his retirement in this area! :)
    xschop Posts: 4,684
    That nasty word... Shipping
  • Gardenstater
    Gardenstater Posts: 4,183
    How about Larry's Arcs? Wouldn't be so expensive to ship and would be installable without bending for the Passive.
    George / NJ
    Crown D150 amp
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • ptrooper
    ptrooper Posts: 501
    Wanted ,full set for 1.2's
