Going Sealed..
Odd that you're having problems posting pics. That to me was one of the very few improvements vanilla brought to the table...
I found it odd to...unless I'm doing it wrong. I tried using the "attach file" icon where you leave the comment..didnt work for me. Is there another way? I'm using an IPad..My Setup: Denon AVR X3600h, Polk Signature S50 Fronts w/ S30 Center and S15 Rears, LG UBK90 4K Player, TCL 6-Series 65”4k TV
When you push the attach file button, it should pull up the option to either use existing photos or take a new photo (it basically works the same as when you try to text a pic). I think that's the only way to do it on an iPad but I could be wrong...Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es; Squeezebox Touch with Bolder Power Supply
Bedroom 2.1Cambridge Azur 551r; Polk RT25i; ACI Titan Subwoofer -
I do this for iPhone and works flawlessly.
2 channel:
Theater:
Focal Aria 926,905,CC900, SVS PB ultra x2. Pioneer Elite SC85, Oppo BDP93, Panamax M5400PM, Minix neox6, Nordost Blue heaven LS power cables. -
Alright guys, I'm not having any luck here . Whenever I click,tap or push on the attach file icon ( icon looks like a sheet of paper with the right corner folded ) nothing happens..? Actually, I tried the other icons as well thinking maybe its just that particular icon, but NONE of them pull up any options of any kind..nothing happens. ??My Setup: Denon AVR X3600h, Polk Signature S50 Fronts w/ S30 Center and S15 Rears, LG UBK90 4K Player, TCL 6-Series 65”4k TV
Then click on choose file....see screen shot below.
Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
Hi vmaxer. Thanks for the screen shot. Unfortunately, that prompt doesn't even pop up when I click on the icon...nothing happens at all. I don't get it...My Setup: Denon AVR X3600h, Polk Signature S50 Fronts w/ S30 Center and S15 Rears, LG UBK90 4K Player, TCL 6-Series 65”4k TV
I think he means the folded page prompt, just above the "leave a comment" box.
