CSiA6 Q&A please clarify
afterburnt
This is from the Polk product page:
>>MikeG
· 2 months ago
I have monitor 70s up front along with the CS2. Would this be a worth-while upgrade to the center channel? Will it timbre match with the monitor 70s?
Polk_Support_Ken
· 2 months ago
Yes, they are matched to each other.<<
This is the first time that I have seen that the CSiA6 and Monitor 70's are matched. Is this true?
Bruce
>>MikeG
· 2 months ago
Polk_Support_Ken
· 2 months ago
Bruce
Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
So "Polk_Support_Ken" is wrong?
I never looked into, but it is possible the two series share the same tweeter. That said, I'd rather have all the same series in my HT rig, at least the front three.Political Correctness'.........defined
President of Club Polk -
RtiA5 buy one get one free you should take advantage of that, a good match for your CsiA6, for that perfect front stage. I know you knew that the 70's weren't timbre matched to your new center but the A5's are at half price you should consider them.Home Theater
Polk Audio Boom Swimmer, Polk Audio Urchin -
gudnoyez I see buy one get half off the second one. Where do you see buy one get one free?
My bad 50% off the second speaker that's still a deal.Home Theater
Thanks for the heads up maybe I can catch them on FF deal down the road. I am tapped out right now. I sure do like this csia6 even though it's not dialed in yet. The improvement over cs20 is immediately obvious.
