Legacy Audio Focus Crossover Modification Thread
24
    VR3 Posts: 28,019
    https://youtu.be/q-ivpubOpKY
    Attached is a video of JUST*** the tweeter(s) and midrange circuits playing.
    This is a direct A/B test between modified (no burn in) and stock. I am running the same channel, same unit and controlling the A/B with a remote.
    Please note that the stock crossovers uses their stock wiring and I am using nicer wire to go from the amplifier to the stock unit.
    The modified units is piece-milled together using alligator clips, cheap thin wire and chewing gum in comparison.
    The recording starts off with the modified units playing first
    (Drivers in back go to modified unit/Drivers in front go to stock unit)
    VR3 Posts: 28,019
    VR3 Posts: 28,019
    VR3 Posts: 28,019
    VR3 Posts: 28,019
    edited May 2015
    This is with the crossovers in place, template fit test
  • drumminman
    drumminman Posts: 3,396
    Trey, that looks stunning. If it sounds as good as it looks your customer will be very pleased.
    tonyb Posts: 32,906
    That bad boy is huge. Same size as a bookie. Is there a reason Trey it had to be that big or are you adding some goodies to make it so ?
    VR3 Posts: 28,019
    Thank you guys! :)
    The size of the parts required this size and I actually removed parts that were associated with the trim sections. There are just a lot of parts and the inductors needed space. I measured all of the inductors in their positions to make sure they were not having any interference from other inductors so the spacing is very particular.
    tonyb Posts: 32,906
    Trey, when the owner has them in place and burned in, I'd be very interested in his thoughts. Hopefully either you or him can post it up here.
  • erniejade
    erniejade Posts: 6,313
    Stunning work. Looks amazing!
    VR3 Posts: 28,019
    Thank you sir ! :)
    VR3 Posts: 28,019
    The owner is doing the side panels, he is weighing a type of acrylic or wood
    VR3 Posts: 28,019
    I agree, that is part of why I mounted the components in the center facing each side versus just bolted to the tabs. I feel this really differentiates the build from other modders and is a great mounting method, very strong and tight.
    VR3 Posts: 28,019
    Thank you very much, I am humbled everyday by some of the things people approach me with and ultimately allow me to design things to my liking (to an extent) and kind of push the envelope of what kind of build can be made
    VR3 Posts: 28,019
    edited May 2015
    Getting closer to making sound
  • Moose68Bash
    Moose68Bash Posts: 3,842
    edited May 2015
    Trey,
    Remarkable!
    Or, to quote DSkip, "stupid good"!
    You continue to raise the bar from design to design.
    Well done,
    VR3 Posts: 28,019
    Thank you Phil :)
    VR3 Posts: 28,019
    Except some minor finishing touches, one is burning in a little :)hw6r7sftox9h.jpg
    tonyb Posts: 32,906
    edited May 2015
    DSkip wrote: »
    I like the idea of transparency and being able to see completely through the unit. Put a little LED in there and it could become a massive conversation piece.
    Agreed, made that suggestion earlier. Plus it's free advertising for Trey and his work. You look at that puppy illuminated in the dark and people are going to ask questions. You post a pic on forums and people will ask questions.
    Only one thing missing now. Some white Fairy dust from Coconut audio around those wires. lol
    Trey, post up some pics when it's all done and set up with the speaks. Very interested in the final outcome and look....and of course sound.
  • drumminman
    Hey Tony, you gettin' inspired to send your Legacy Xovers for a little refresh? I'm guessing that work costs what used car goes for
    tonyb Posts: 32,906
    drumminman wrote: »
    Not as of right now, but when the time comes, who knows. I may just hold out for those Aeris to come down in price on the used market.
    VR3 Posts: 28,019
    The finish line is near! :smile:cd8ba0b44a15c10065fd-24461f391e20b7336331d5789078af53e3d0v8wu8sp.jpg
    3.r23.cf1.rackcdn.com/polkaudio.vanillaforums.com/editor/bf/jnmrpk2nsasu.jpg
  • Moose68Bash
    Awesome, Trey.
    Absolutely awesome! :)
    VR3 Posts: 28,019
    edited May 2015
    Thank you Phil!! :-D
    Reminder that these are .50 cent tweeters ;-D
    https://www.youtube.com/watch?v=6EmgRHG-FoI
  • TCK
    TCK Posts: 231
    Mule!
    - SDA 2B (1989, Oak Tops, 194s, Spikes)
    - Monitor 7B (1982 Peerless, Sonicaps, Mills, Dynamated, JB Welded, Binding Posts)
    - SVS SB12-NSD (2 in Flat Black)
    - SVS SB 3000 (Gloss Black)
    - Pioneer SC-1222K AVR
    - Marantz MM 7055 (5 Ch Amp)
    - Pioneer PD-D6 SACD Player
    - Marantz NR1403 AVR
    - Sony UBP-X800M2 (4k Blu-ray)
    - Sony UBP-X1100ES (4K Blu-ray)
    - Adcom GFA 555
    - Monitor 5 (194s, Side Surrounds)
    - Monitor 5Jr+ (194s)
    - LG OLED65CXPUA (4K OLED TV)
    - LG 55UN7300PUF (4K HD TV)
    - RT35i (Cherry)
    - CS400 (Center)
    - CS350 (Center)
    - F/Xi A4 (Rear Surrounds)
    - RT25 (Rear Surrounds)
    - Audioquest Cables
    " But boy do I remember the strain of her refrain " LG
    VR3 Posts: 28,019
    Government Mule is great, on that particular CD there are two tracks that are a real Audiophile treat for sure, great imaging. I find that modifications really bring out the snare and cymbals in the recording.
    VR3 Posts: 28,019
    Here is another - this is with the drivers on the same plane
    This is with a $100 Insignia receiver, .50 tweeters, Definitive midbass drivers and Xbox 360 source
    https://www.youtube.com/watch?v=hMxUHlW7YOI
    VR3 Posts: 28,019
    The inputs are the highs mids and lows, it is set up for tri wire
    Thank you :)
    VR3 Posts: 28,019
    I made some custom inserts to go inside the units for shipping.
    These weighed in at 75 pounds shipping weight! :)yp30jllti5u0.jpg
  • blehmbo
    blehmbo Posts: 179
    very nice and clean. they look great.
