Legacy Audio Focus Crossover Modification Thread
https://youtu.be/q-ivpubOpKY
Attached is a video of JUST*** the tweeter(s) and midrange circuits playing.
This is a direct A/B test between modified (no burn in) and stock. I am running the same channel, same unit and controlling the A/B with a remote.
Please note that the stock crossovers uses their stock wiring and I am using nicer wire to go from the amplifier to the stock unit.
The modified units is piece-milled together using alligator clips, cheap thin wire and chewing gum in comparison.
The recording starts off with the modified units playing first
(Drivers in back go to modified unit/Drivers in front go to stock unit)- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
3D Printed cable collar
This is with the crossovers in place, template fit test
Trey, that looks stunning. If it sounds as good as it looks your customer will be very pleased."Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer
That bad boy is huge. Same size as a bookie. Is there a reason Trey it had to be that big or are you adding some goodies to make it so ?HT SYSTEM-
lsi 9's -
Thank you guys!
The size of the parts required this size and I actually removed parts that were associated with the trim sections. There are just a lot of parts and the inductors needed space. I measured all of the inductors in their positions to make sure they were not having any interference from other inductors so the spacing is very particular.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Trey, when the owner has them in place and burned in, I'd be very interested in his thoughts. Hopefully either you or him can post it up here.HT SYSTEM-
lsi 9's -
Stunning work. Looks amazing!Klipsch The Nines, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's.
Thank you sir !
I will definitely post any thoughts the owner provides
The owner is doing the side panels, he is weighing a type of acrylic or wood- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
I agree, that is part of why I mounted the components in the center facing each side versus just bolted to the tabs. I feel this really differentiates the build from other modders and is a great mounting method, very strong and tight.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Thank you very much, I am humbled everyday by some of the things people approach me with and ultimately allow me to design things to my liking (to an extent) and kind of push the envelope of what kind of build can be made- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Getting closer to making sound
Edited to remove schematic from pictures
Trey,
Remarkable!
Or, to quote DSkip, "stupid good"!
You continue to raise the bar from design to design.
Well done,Family Room, Innuos Statement streamer (Roon Core) with Morrow Audio USB cable to McIntosh MC 2700 pre with DC2 Digital Audio Module; AQ Sky XLRs to CAT 600.2 dualmono amp, Morrow Elite Speaker Cables to NOLA Baby Grand Reference Gold 3 speakers. Power source for all components: Silver Circle Audio Pure Power One with dedicated 20 amp circuit to main panel.
Exercise Room, Innuos Streamer via Cat 6 cable connection to PS Audio PerfectWave MkII DAC w/Bridge II, AQ King Cobra RCAs to Perreaux PMF3150 amp (fully restored and upgraded by Jeffrey Jackson, Precision Audio Labs), Supra Rondo 4x2.5 Speaker Cables to SDA 1Cs (Vr3 Mods Xovers and other mods.), Dreadnaught with Supra Rondo 4x2.5 interconnect cables by Vr3 Mods. Power for each component from dedicated 20 amp circuit to main panel, except Innuos Statement powered from Silver Circle Audio Pure Power One. -
Thank you Phil- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Except some minor finishing touches, one is burning in a little
I like the idea of transparency and being able to see completely through the unit. Put a little LED in there and it could become a massive conversation piece.
Agreed, made that suggestion earlier. Plus it's free advertising for Trey and his work. You look at that puppy illuminated in the dark and people are going to ask questions. You post a pic on forums and people will ask questions.
Only one thing missing now. Some white Fairy dust from Coconut audio around those wires. lol
Trey, post up some pics when it's all done and set up with the speaks. Very interested in the final outcome and look....and of course sound.
lsi 9's -
Hey Tony, you gettin' inspired to send your Legacy Xovers for a little refresh? I'm guessing that work costs what used car goes for"Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer
drumminman wrote: »Hey Tony, you gettin' inspired to send your Legacy Xovers for a little refresh? I'm guessing that work costs what used car goes for
Not as of right now, but when the time comes, who knows. I may just hold out for those Aeris to come down in price on the used market.HT SYSTEM-
lsi 9's -
The finish line is near!
3.r23.cf1.rackcdn.com/polkaudio.vanillaforums.com/editor/bf/jnmrpk2nsasu.jpg
Awesome, Trey.
Absolutely awesome!Family Room, Innuos Statement streamer (Roon Core) with Morrow Audio USB cable to McIntosh MC 2700 pre with DC2 Digital Audio Module; AQ Sky XLRs to CAT 600.2 dualmono amp, Morrow Elite Speaker Cables to NOLA Baby Grand Reference Gold 3 speakers. Power source for all components: Silver Circle Audio Pure Power One with dedicated 20 amp circuit to main panel.
Thank you Phil!! :-D
Reminder that these are .50 cent tweeters ;-D
https://www.youtube.com/watch?v=6EmgRHG-FoI- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Mule!- SDA 2B (1989, Oak Tops, 194s, Spikes)
- Monitor 7B (1982 Peerless, Sonicaps, Mills, Dynamated, JB Welded, Binding Posts)
- SVS SB12-NSD (2 in Flat Black)
- SVS SB 3000 (Gloss Black)
- Pioneer SC-1222K AVR
- Marantz MM 7055 (5 Ch Amp)
- Pioneer PD-D6 SACD Player
- Marantz NR1403 AVR
- Sony UBP-X800M2 (4k Blu-ray)
- Sony UBP-X1100ES (4K Blu-ray)
- Adcom GFA 555
- Monitor 5 (194s, Side Surrounds)
- Monitor 5Jr+ (194s)
- LG OLED65CXPUA (4K OLED TV)
- LG 55UN7300PUF (4K HD TV)
- RT35i (Cherry)
- CS400 (Center)
- CS350 (Center)
- F/Xi A4 (Rear Surrounds)
- RT25 (Rear Surrounds)
- Audioquest Cables
" But boy do I remember the strain of her refrain " LG -
Government Mule is great, on that particular CD there are two tracks that are a real Audiophile treat for sure, great imaging. I find that modifications really bring out the snare and cymbals in the recording.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Here is another - this is with the drivers on the same plane
This is with a $100 Insignia receiver, .50 tweeters, Definitive midbass drivers and Xbox 360 source
https://www.youtube.com/watch?v=hMxUHlW7YOI- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
The inputs are the highs mids and lows, it is set up for tri wire
Thank you- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I made some custom inserts to go inside the units for shipping.
These weighed in at 75 pounds shipping weight!
very nice and clean. they look great.
