Passive Radiator Repair
teamjhertz
I have a passive radiator that needs repair. The cone is coming unglued from the spider in one spot on the radius. The spider appears to be fine with no tears. I am hoping that i can just add some new adhesive to repair. Any recommendations on what type of adhesive to use? I emailed the manufacturer as well and await their response.
A little two part epoxy and it is operational once again
I am so sorry I did not see this sooner, but it looks like you read my mind anyway. I hope you used it sparingly.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2300 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
“When once a Republic is corrupted, there is no possibility of remedying any of the growing evils but by removing the corruption and restoring its lost principles; every other correction is either useless or a new evil.”— Thomas Jefferson -
Thanks for the response. I did place a bead that was slightly wider than the original, but it looks like the spider moves freely. Time will tell how long it will last
