My Custom Speaker Stands
marine5068marine5068 Posts: 4
edited July 2014 in Custom Fabrication
Custom Fabricated Speaker Stands
Materials:
a) 1/4" thick aluminum plate for 12"x12" bottom plates and for the 6.5"x11" top plates.
b) 2"x4" extruded aluminum angles to make a rectangular vertical tube for the risers.
c) 1/4" thick, peel and stick high density rubber for the isolation pads on top of the speaker base plates and under the floor base plates.
Post edited by marine5068 on
  • disneyjoe7disneyjoe7 Posts: 11,520
    edited January 2014
    Kool nice work, where you going to leave them as they are or paint them?
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • Toolfan66Toolfan66 Posts: 13,709
    edited January 2014
    Fill the tubes up with sand or lead shot..
  • GlennDogGlennDog Posts: 1,489
    edited January 2014
    nice work . . .
    Welcome to Club Polk!
    Power Rogue M180 monos & Adcom GFA 5802
    PS Audio PerfectWave Power Plant 10
    Rears Definitive Technology BP-2
    Center Definitive Technology C-1
    Pre/Pro Integra DHC 40.1
    Pre Cary SLP-98 Hot Rod
    LCD Samsung LN46B750
    Source Oppo 105
    PS Audio AC-12
    Wires MIT S3.3
  • lanchilelanchile Posts: 566
    edited January 2014
    Very nice stands, paint them with flat black paint (spray). I have to agree with the sand filling thing! Metal speaker stands can resonate. I am in the process of building my "wood" speakers stands with material from Home depot (no more than $30)
    Make it simple...Make it better!
  • hewlew1hewlew1 Posts: 153
    edited January 2014
    Very nice . I built a pair of stands from old planking which I removed from a house that I am redoing. Cost me only about three bucks for 3 cans of black spray paint.
  • zane77zane77 Posts: 1,711
    edited January 2014
    Very nice welding job, I agree fill the risers with sand or shot.
    Two Channel
  • ken brydsonken brydson Posts: 6,961
    edited January 2014
    hewlew1 wrote: »
    WHERE DID YOU FIND THE PAINT???? :cheesygrin:
    HT/Main- Panny 50" G10 Plasma, Pioneer SC-1222k AVR, Panny DMP-BD60 BDP, Polk LS90 mains, CS350LS center, LS/fx side surrounds, LS50 surround backs, SVS 25-31PC+ sub, Harmony One
    Office Rig- Marantz 2252B, Denon 2910, Kenwood KD2070 TT, Polk RTA 12B's/ RTA8t
  • jacks2startjacks2start Posts: 103
    edited January 2014
    nice work
  • dbKillerdbKiller Posts: 320
    edited January 2014
    When will you be taking orders? I have a set of RT55's that would be at home on those!
    Home Theater: LG 60PB450; Pioneer Elite SC55; RT2000P; RT55P; CS400p; FX500; SVS PB12-Plus/2; PS3 360GB
    Office: Onkyo TX-NR616; RT2000i; RT800i; CS400i; DSW Micropro 4000; XBOX 360 250GB; LG BR370; Panasonic Plasma
    Bedroom: Sony STR-DH820; CS400p; RT55p; Sony Grand Wega 55"
    Retired: Sony STR-DN840; Yamaha HTR-6130; Sony STR-DN520; Paradigm Phantom V.3; Paradigm CS-270V.3, Cinema ADP V.3, PS1000 V.4; Polk S6; Onkyo TX-NR809; Monitor 50, CS1; FXi3; PSW350
  • xjghostxjghost Posts: 936
    edited January 2014
    Nicely done. I would love to learn aluminum welding.
    HT/2Channel: Emotiva MMC-1, Adcom GFA-555II, Polk SDA 3.1's, Teac TN-300 TT, Polk Center and Sub.
    Bedroom system: Carver CT-24, Parasound HCA-800II, Monitor 10's
    Additional projects: RTA 12c's
  • madmaxmadmax Posts: 12,438
    edited January 2014
    My initial thought too!
    Vinyl, the final frontier...
  • 20hz20hz Posts: 643
    edited May 2014
    I like the stands ! did the heat bend the plates at all ?
    Did you angle the top plate ?
    I wouldnt paint them maybe rattle can some satin clear coat on them ..
  • deafbykhornsdeafbykhorns Posts: 150
    edited May 2014
    I like the idea about filing with lead or sand, seems like the alum might ring some
    I filed mine with grout
    Main System- Scratch built 2A3 , Lightspeed preamp, Technics SP15/Graham/XV1s,Klipschorns w/ALK xovers/Trachorns, Speakercraft MT8(4), Sonos ZP90, Yamaha Aventage for surround
    Office System- Adcom GTP500, Bedini 45/45,Lexicon RT-20,Enlightened Audio DAC, Polk SDA2.3TL, Northcreek Borealis
  • shawn474shawn474 Posts: 2,786
    edited May 2014
    I would consider bedlining them; gives them a textured finish with durability and grip.
    Shawn
    Pre-Amp: Marantz AV-7005 Pre
    Amp: B&K AV5000 Series II
    Center Channel: Polk LsiM706c
    Front: Polk LsiM703
    Rear: LSI fx
    Subwoofer: SVS 20-39pci
    Television: Samsung LN46B640
    DVD Player: Sony BDP-S1000ES
  • lilylily608lilylily608 Posts: 15
    edited May 2014
    thanks for your sharing!
  • PhatattackPhatattack Posts: 30
    edited May 2014
    Sick stands! Black anodized and i want a set :)
  • Moose68BashMoose68Bash Posts: 3,525
    edited May 2014
    Great stands! I agree with the black anodized suggestion -- lloks great on aluminum.
    Family Room, PS Audio PW Transport, DirectStream DAC; AQ Sky XLRs, Perreaux SM6 MKII Pre; AQ Sky XLRs, Perreaux Prisma 750 Amps or CAT 600.2 Dualmono Amp, Morrow SP7 Speaker Cables, SDA SRS 1.2tls (RD0198s, Dreadnought, Black Hole 5, Acousta-Stuf, Dynamat Extreme, JBWeld. Vr3 Mods: "The Abbot" Monastery-Level Xovers, Custom Internal Wiring, Binding Post Plates, & SDA ICs).
    Exercise Room, Wadia 171 iPod Dock, PS Audio PerfectWave MkII DAC, AQ Sky XLRs, Perreaux SM6 Preamp, AQ King Cobra RCAs, Perreaux PMF3150 Amp, Dreadnought, Supra Rondo 4x2.5 Speaker Cables, SDA 1Cs (Vr3 Mods Xovers).
    Synology 713+ NAS on Gigabit LAN serving PW MkII DAC & DirectStream DAC.
  • SeaSea Posts: 319
    edited June 2014
    Very Nice.
    Main-Carver TFM35(2),Carver C11 ,Carver SD/A 360 CD,Carver TX11 ,Grace Digital Tuner, Pioneer PL707 TT,Polk SDA1C
    Downstairs -Carver M1.5t, Carver C1 Pre, Carver TX10 Tuner, Carver TL3200 CD Player, Dual 1009 TT,Polk SDA SRS 2.3tl
    Study - Carver AV634 Amp, Carver CT7 Pre, Carver DTL50 CD Player, Polk RTA12c
  • cnhcnh Posts: 13,310
    edited June 2014
    Nice industrial look and probably indestructible.
    Question to all the folks above. Now that the metal is "welded" just how would you fill it with sand or shot? Use a "transporter to beam the material inside?
    cnh
  • gcegce Posts: 2,138
    edited June 2014
    cnh wrote: »
    cnh
    Drill a hole in the top! :rolleyes:
    Anaheim Hills CA,
    edited July 2014
  • deronb1deronb1 Posts: 4,210
    edited July 2014
    Long strip of dynamat along the back might help with the ringing if you dont want to fill
  • kdblove_99kdblove_99 Posts: 108
    edited July 2014
    I would also paint them
  • strokinstrokin Posts: 63
    gce wrote: »
    cnh wrote: »
    cnh
    I was thinking the same thing.
  • la2vegasla2vegas Posts: 2,504
    Rustoleum makes a very good product in different colors with different textures. I personally like their hammered texture in black.
    2.3TL, 3.1TL, SDA 2B, SDA II, 7B, 7C, 7 series 2, 10B, 5JR+, 5JR, 5A, 4.5, 4, RTA 11T X2 pairs, RTA 8T, LSI9, LSI7, RTI A7, RTI A3, CSI A4, CSI A6, F/XI A4, RTI4. That's all for now.
  • ThomasDThomasD Posts: 145
    Just found this thread and had to resurrect it . I'm stoked 'cause this is exactly what I've been contemplating to use to make stands for my 7's. I can't weld to save my life but I have a friend who is an incredible aluminum welder, it's his profession. Just wanted to check to see if there was anymore information / conclusions about mass filling or finishing the aluminum.
    marine5068 wrote: »
    Materials:
  • F1nutF1nut Posts: 39,784
    You definitely do not want rubber pads between the stand and floor. Spikes are the name of the game there.
Howdy, Stranger!
