4 Shot Backwards Compatible
aDzDooM
Quick questions,
1. will the Xbone Polk 4 Shots be usable on my xbox 360? and,
2. when Microsoft add functionality to the Xbone for virtual surround will the polks offer that via a device similar to what the melee use?
Post edited by aDzDooM on
The 4Shots won't work with the Xbox 360. You need the Melee, which has the optical cable to provide the audio since the Xbox 360 does not provide game audio through the controller like the Xbox One does.
IF Microsoft adds simulated surround sound wirelessly to the Xbox One controller then yes, the headset will work with it. However, I don't believe they have said if it's coming or not. -
Is it possible to order the optical cable to make the 4shot backwards compatible?
