Hurricane Nuts
Faustin
Looking for advise on using hurricane nuts and machine screws on larger passive radiators. Most of the original pr's use only 4 of 8 holes to fasten the pr to the cabinet. Is it recommended to use all 8 holes and drill out and install hurricane nuts, or just use the 4?
Post edited by Faustin on
I'm sure you would be fine with just the four, but myself would do all eight...
Other than the CRS/CRS+, what other SDA's only use 4 of the 8?
Anyway, do all 8.Political Correctness'.........defined
President of Club Polk -
Anyway, do all 8.
That's the only one, but all the monitors use 4, but I know you know that.. LOL!!! :-) -
Thanks for the input. Spaecifically it would be for monitor 10's and RTA 12's.
Yep, use all available holes. You'll get much better coupling of the PR to the front baffle, less chance for air leaks."Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer
Just received an order of hurricane nuts from PE. They stick to a magnet. I thought I read somewhere in here that this is a problem? What's the scoop? Thanks
It’s not a problem... Rock On.....
Domo arigato, Larry-san.
