I want to know what Qms
jacksportsjacksports Posts: 4
edited December 2013 in Custom Fabrication
I want to know what Qms, Vas and Qes means?
Post edited by jacksports on
  • mhardy6647mhardy6647 Posts: 17,646
    edited November 2013
    These are three of the parameters used to quantify the performance characteristics of a loudspeaker driver; three of the so-called "Thiele-Small" parameters. The T-S parameters are used to "fit" a driver to an enclosure (or, to think about it conversely, to "tune" an enclosure to a given driver). Arguably, the full gamut of T-S parameters is most important for woofers, but in practice the parameters may be determined for any driver and may be useful for MR and tweeters, too - if for no other reason than to select crossover frequencies.
    Here's a personal favorite primer on measurement of T-S parameters. It identifies the important parameters, even if the definitions given are a bit circular :-)
    http://sound.westhost.com/tsp.htm
    Definitions:
    Re Electrical [i.e., DC] resistance of voice coil
    Fs Resonant frequency of loudspeaker moving mass (in free air)
    Qes Electrical Q of loudspeaker ["Q" describes the shape of the peak of the impedance curve around Fs (see the figure below) - high "Q" = high, sharp "mountain peak"; low "Q" = broad, low "hill"]
    Qms Mechanical Q of loudspeaker
    Qts Total Q of loudspeaker [see the link to see how Qms and Qes relate to Qts]
    Vas Equivalent air volume of moving mass suspension [this is a measure of the compliance or, I ould say, the "floppyness" of the driver's suspension]
    Note the impedance peak around Fs - this is the "Q" curve. The impedance is fairly flat around 100 to 200 Hz; this is where the "nominal" impedance figure comes from. At higher frequencies, the impedance rises due to the "inductance" of the speaker's voice coil.
    There are some very good books on the subject of loudspeaker (enclosure) design - I like David Weems' books and Ray Alden's books. Vance Dickason's Loudspeaker Design Cookbook is another classic design reference.
    EDIT: Google turned up some more explanatory pages :-)
    http://www.speakerplans.com/page89.html
    http://www.eminence.com/support/understanding-loudspeaker-data/
    "It's like watching a roomful of people who couldn't get through college algebra discussing the flaws of quantum physics theory. I guess it could be fun, but it's ultimately a waste of time." -- seen on audiokarma
    "Some amps run on self bias, some amps run on fixed bias. But his amps run on confirmation bias." -- seen on audioasylum
    "Writing about hifi is like dancing about architecture" -- paraphrasing some wag (possibly Frank Zappa)
  • pitdogg2pitdogg2 Posts: 9,831
    bet this went zoom right over their head:)
    ahh, well... we do what we can. That "speakerplans dot com" has a pretty good nontechnical explanation of what the parameters mean.
  • MacLeodMacLeod Posts: 14,365
    Ive been in this hobby since 1988 and the sport as a competitor since 2005 and I STILL dont have a clue what all this T/S parameters is about. All I know is that you need a Qts of .40 or higher to run a speaker in infinite baffle and .71 Qts is considered perfect (flat). I kinda know what resonant frequency (Fs) means that basically it shows you how competent the driver is at lower frequencies like a tweeter with a Fs of 750 like the Scan Illuminator is going to work a lot better crossed over at 2.5KHz than a LPG 26NA with its 1500 Hz FS. But thats about it as far as my knowledge goes. I stick to the calculators like WinISD to do all the legwork.
  • FaceFace Posts: 14,714
    Here are some much more advanced "calculators": http://audio.claub.net/software/jbabgy/jbagby.html
    Woofer Box and Circuit Designer makes WinISD look like a toy.
  • SpeedskaterSpeedskater Posts: 497
    Many big libraries have loudspeaker books by (1)David Weems or (2)Vance Dickerson. Both authors start slowly.
    Vance Dickason (that'll make his books easier to find) :-)
    http://www.parts-express.com/pe/showdetl.cfm?partnumber=500-035
  • Polk&BeansPolk&Beans Posts: 94
Howdy, Stranger!
