Sub to match PA880
kaden
What sub (in a prefab box) do you recommend to go with a PA880 (I already own the amp)?
Does the amp have too much power for a db1212?
Does the amp have too little power for a db1222?
Should I be looking at other models or brands (keeping in mind that I am in Australia and I prefer Polk)?
My listening is metal and pop. My current setup is a PA660 on db6501 and db651 in a 2007 Honda Civic Sedan.
Thanks for your advice in advance.
Post edited by kaden on
Anyone?
I have a PA-880 Amplifier powering my db1222 subs and it is amazingly awsome.
More than enough power and it sounds incredible. It reproduces the lowest lows I have ever heard without 15" subs.
Definitely reccomend the pairing of the two. -
Doit!
