Psw10 Subwoofer emitting strange sound
RomeodaddyRomeodaddy Posts: 1
edited October 2013 in Forum Testing Area
Recently had to disconnect the sub to paint the room, was working fine. When I reestablished the subwoofer connection, the subwoofer emits a strange constant sound, sounds like ummmmmmmmmmm
Subwoofer connection to receiver (sub pre-out)
Y split cable to subwoofer
Low pass set to 180
Phase switch - have tried each position
Am I doing anything wrong? Did something happen to the subwoofer?
Dean
Post edited by Romeodaddy on
  • MarkTXMarkTX Posts: 58
    edited October 2013
    unplug the cable going into the back of the subwoofer, is the hum gone? possible ground issues from the receiver, y-cable, etc. worse case you could float it. are you using the exact same power outlets, locations, cables, etc as before?
Howdy, Stranger!
