polk momo burnt
harinarayanks
harinarayanks Posts: 4
edited July 2013 in Car Audio & Electronics
I got a polk momo 15" 4 ohm dvc subwoofer
-400watts rms
and my amplifier is cerwin vega 500.1 monoblock
rms@4 ohms -300watts
rms@2 ohms -500watts
i connected the subwoofer in series connection @ 2 ohms and it was working good for soo many days.But my subwoofer had burned last day when i raise the bass in my remote bass controller. :(
what will be the reason?
please help me :(
i connected it in this way
Post edited by harinarayanks on
  • MacLeod
    MacLeod Posts: 14,358
    edited June 2013
    Where is your gain set? Chances are you clipped the amp by turning it up too far and fried your sub.
  • Dragolith
    Dragolith Posts: 8
    edited July 2013
    More then likely the raise in the remote control bass is what did it, more then likely distortion had set in causing the sub to go since distortion is a big killer in subs, and if you had it in the trunk you might not of noticed it happening since the back seat usually acts like a distortion baffle!
    Alpine CDA-7863 HU
    Alpine MRP-M240 50x4 F&R amp
    Alpine MRV-M450 Sub Amp (2ohms)
    Polk Audio DXi124 DVC (2ohms)
    Alpine SPS-510 x4 F&R Speakers
    Alpine CHA-S604 6 disk CD-Changer
  • nguyendot
    nguyendot Posts: 3,594
    edited July 2013
    Thats actually wired in parallel if that's a monoblock.
    Main Surround -
