DB6750 - Hard to find!
Screamin
All my fave Internet retailers (Sonicelectronix, cardomain, etc) are sold out of the DB6750! I'm certainly not as "up to date" as most around here...is Polk releasing a 6751, or is there something else afoot? Thanks.
Post edited by Screamin on
The new db651 is the replacement. It has over- sized mounting holes, with adaptor rings to step down to "traditional" 6" holes.
I would imagine the Polkies can get you a couple for a modest cost...
But, if they can't, you can take some 1/2" MDF (fiberboard... or even you want even plywood or any wood) and shave the heck out of it unit it fits.
I did it with a set of Crystal 6.5's (6.75), and it worked out allright. I just wish I used some better wood... the crappy plywood I had splintered up terribly.The Artist formerly known as PoweredByDodge -
The adaptor that comes with the 651 wouldn't work if you're trying to make the old 650 fit where a 675 should. The outer holes on the adaptor rings are small so a screw will "bite" and the inner holes are larger for a screw to pass through.
I am looking for (2) DB6750. Let me know if you or anyone wants to sell them. Thanks! E-mail.
