Installation advice for my Wrangler JK
oOoYTSEJAMoOo
Hello ladies and gents!
Looking for advice on how to wire my Polk setup in my Jeep. I will be running from the factory radio, but through an AudioControl LC6i signal converter. I will be running the following speakers and a PA660 amp. I am looking for suggestions on how I should best run this for optimum sound with these current components, and not by adding anything else. I really appreciate your input!
Dash - Db1001 tweeter pair
Lower dash - 651s pair
Sound bar - 651s pair
Sub - MM 10 inch dvc
Thanks!
Weston
Thanks!
Weston
Post edited by oOoYTSEJAMoOo on
I meant to add...I listen to progressive metal, rock, and talk radio - so tons of bass isn't a huge priority. A good clean sound is my aim.
nice try stefan, reportedIf you can't hear a difference, don't waste your money.
