Advice?add a sub to stock radio&new speakers
datsunscott
I want to keep my stock head unit.
So I decided on installing new DB651's in the front and rear doors as they should work pretty good and barely fit. And I want to add a sub in the back to run off the stock head unit too. I have speaker level outputs only.
Can I run my speaker wires in parallel ( run the speakers and connect the same circuit to the amp) with high level inputs into the amp for a sub and not lose the stock head unit power to the speakers?
Or will connecting speaker level inputs from the existing speaker wire to the amp "suck the power" out of the speaker leads and kill or reduce the DB651 sound?
Should I be looking at an amp with high pass filters?
Post edited by datsunscott on
2003 Subaru Outback= can fit replacement DB651s in frt + rear doors, want to add some bass in the back side panel. The stock "premium" subaru headunit should push the DB651s ok, and it has AM/FM/6CD changer and Weatherband- I want to keep the weatherband.
good advice, that's exactly what I would have said to do.Truck system so far...
2007 Dodge Ram 1500 quad cab Hemi
Kenwood KDC-X492 HU
MM651 coaxials in doors
Family Room:
Panasonic TC-P50G25 50" Plasma
Panasonic DMP-BD655K BDP
XBOX 360 250GB
Harman/Kardon HK3480(on loan)
Monitor 70 Series II -
To answer your original question, no it won't effect how much power your speakers receive.
However, the advice given by DSkip is right on and would sound better than what you intend to do.polkaudio | the speaker specialists
Eclipse AVN6620
Polk SR5250 (passive, 200w x 2)
Polk SR104 DVC (series, 400w x 1)
Earthquake 900w.5 (weak link - need upgrade)
Rockford Fosgate Wiring & Accessories -
You dig up a 3 year old thread to start spamming in? What an ****. BTW, REPORTED.If you can't hear a difference, don't waste your money.
Yep, hate that stuff.Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404
