Polk MoMo setup on a boat
Ghblue
I have a 26' boat I want to install four 6.5" MoMo speakers and a 10" Sub. Obviously I'll need a amp.
What are your thoughts. Previously I looked at JL audio.
Thnx in advance
Thnx in advance
Post edited by Ghblue on
Which sub and which amp should I buy?
Don't know much about the subject, but my fishing buddy sports clarion marine amps?2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
I'm installing 4 MM651's and 2 MM1040's using 2 PA-D4000.4 amps in my 38 Fountain. Do yourself a favor and take the time to build a box for the sub, I covered the boxes with marine grade vinyl. IF you decide to use 2 subs and one of these amps to power it, please note the instructions are poor, what I found after many hours of cussing and posting on here was....
The problem was the instructions, or should I say, the lack of instructions. While the instructions do show you what is printed right on the amp, it does not elaborate on any of the settings when connecting 2 bridged subs. As per the instructions, used FRONT inputs,set to stereo, BPF, adjusted levels...... only on the FRONT side, NOWHERE does it tell you to set the adjustments for REAR. A little less information on the obvious and, a little more on the details would be a better manual
