How DACs work - White paper
BlueFox
BlueFox Posts: 15,251
edited March 2013 in Going Digital
I came across this while looking into their products. It is a great explanation for those new to standalone DACs, and it also applies to the DAC in a CD player.
http://www.msbtech.com/support/How_DACs_Work.php?Page=supportHome
Now I need to scrounge up $10k and buy their DAC. :smile:
Post edited by BlueFox on
  • bikerboy
    bikerboy Posts: 1,207
    edited December 2012
    I always get a laugh when people say it's just ones and zeros. Timing(jitter) is something that seems to be an important issue as of late. I think I'll be staying with the Buffalo for now. $10k and its old and out of date the day you buy it. Yikes!
    Main system: Lyngdorf TDAI 2170 w/ Pioneer 42" plazma-> Polk LSiM 703 w/Tivo, Marantz tuner, BRPTT: Nothingham Spacedeck-> Pioneer PL L1000 linear arm-> Soundsmith DL 103R-> SUT->Bottlehead ErosDigital: I3 PC w/ Jriver playing flac -> Sonore Ultrarendu -> Twisted Pair Audio ESS 9028 w/ Mercury IVY Vinyl rips: ESI Juli@24/192-> i3 PC server
    tonyb Posts: 32,906
    Yeah man, I'm done buying expensive new gear. It gets obsolete within months, sometimes weeks, and then the value sinks like a rock. Higher end audio, aside from a few exceptions, doesn't hold value very well. Buy used at practically half price and save yourself a small fortune.
  • mantis
    mantis Posts: 17,056
    Very Cool thank you
    Dan
  • Lost240
    Lost240 Posts: 176
    edited February 2013
  • KrazyMofo24
    KrazyMofo24 Posts: 1,195
    edited March 2013
    Nice looking forward to reading this.
    Setup:
    2 Channel: Vienna Acoustics Mozart Grand, T+A P 1230R, Primare SPA21, Oppo BDP-105
    PC: Vienna Acoustics Haydn Grand, Cambridge Azure 650A v2 , Peachtree iDAC, Denon DVD-3800BDCI
  • soundfreak1
    soundfreak1 Posts: 3,385
    edited March 2013
    tonyb wrote: »
    yeah man, i'm done buying expensive new gear. It gets obsolete within months, sometimes weeks, and then the value sinks like a rock. Higher end audio, aside from a few exceptions, doesn't hold value very well. Buy used at practically half price and save yourself a small fortune.
    bingo!
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
  • KrazyMofo24
    edited March 2013
    DSkip wrote: »
    This is why I'm allocating my 2013 funds to crossover upgrades and not a DAC. I need a good DAC more than anything at this point, but I'm content for the most part with the sound I'm getting out of the Pio. I suspect that in the next 2-3 years, there will be a wealth of USB DAC's available at VERY affordable prices as the market appears to just now be taking off.
    Not a bad idea. You definitely aren't in a desperate need for a DAC with the Pioneer as your source. Not sure if the prices are going to change much in the next two years but I do hope so. There are already plenty of cheap and affordable usb dacs but it would be nice if the higher end ones drop in price.
    Setup:
