Polk Audio LSiC Crossover Modification Thread
VR3
This should be fun!
Will be a Fortress "stack" modification but with remote mounted parts...
This will also feature a "STOCK" Recording and a "MODIFIED" recording!
Post edited by VR3 on
So trey is this recording thing going to become a standard thing? I think it is pretty cool and a great way to show what the mod does. Maybe post the waveform before, after and then overlaid so you can see what gets added?"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
It will be "normal" for things that I actually have access to..
We will always try to do a direct comparison recording where we will take three particular pieces of a recording and play them back to back!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
My goal is to have an outlet to listen to hundreds of speakers by recording.. any brand, any model...
By the middle of January I should have recordings for -
Definitive Technology PM900
Definitive Technology CLR1000
Polk Audio RT55
Polk Audio RTi10
Polk Audio RTi8
Rogers LS7
Polk Audio LSi9 Stock and Modified
Polk Audio LSiC Stock
M Audio BX5D2
By the end of the month I should have -
Polk Audio SDA 1.2TL Stock
Polk Audio LSiC Modified
And in February or March
Polk Audio SDA SRS 1.2TL Modified
Tyler Acoustics Linbrook Signature Stock/Modified- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
So I guess the real question is how much can you fit inside of a LSiC? a Vr3 Fortress is how much! :-P- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
LSiC with the large inductor broken up into two inductors... made it a bit more challenging- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Nice work under challenging conditions.
By the way, have you ever thought about consulting on organizing closets and basements?
Well done, Trey!Family Room, Innuos Statement streamer (Roon Core) with Morrow Audio USB cable to McIntosh MC 2700 pre with DC2 Digital Audio Module; AQ Sky XLRs to CAT 600.2 dualmono amp, Morrow Elite Speaker Cables to NOLA Baby Grand Reference Gold 3 speakers. Power source for all components: Silver Circle Audio Pure Power One with dedicated 20 amp circuit to main panel.
Exercise Room, Innuos Streamer via Cat 6 cable connection to PS Audio PerfectWave MkII DAC w/Bridge II, AQ King Cobra RCAs to Perreaux PMF3150 amp (fully restored and upgraded by Jeffrey Jackson, Precision Audio Labs), Supra Rondo 4x2.5 Speaker Cables to SDA 1Cs (Vr3 Mods Xovers and other mods.), Dreadnaught with Supra Rondo 4x2.5 interconnect cables by Vr3 Mods. Power for each component from dedicated 20 amp circuit to main panel, except Innuos Statement powered from Silver Circle Audio Pure Power One. -
LOL! I think I could organize a mean closet!
Thanks for the kind words!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Think I finally got it down!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
nicely done.Main Family Room: Sony 46 LCD, Sony Blue Ray, Sony DVD/VCR combo,Onkyo TXNR 708, Parasound 5250,
Living Room: Belkin PF60, Parasound HCA2200, MIT ProlineEXP balanced IC's,Emotiva XDA-1 DAC/Pre,Emotiva ERC2 transport,MIT AVT2, Polk LSI 9's. -
Thank ya sir!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
I just modded the LSiC crossover but have noticed that the left driver is very very quiet, almost silent, while the right one is very loud. The driver I can hear (as well as the tweeter) sound very good, but I'm wondering if maybe I screwed something up. I never really payed close attention before to know if it has always been that way pre-mod or not. Perhaps the center is just not getting a lot of frequencies for that driver? it's crossed at 80hz. Has anyone noticed a driver level difference before/after mod? Thanks.
Used Sonicap Gen1 for the high, Erse PulseX for the low. Mills resistors. -
The left driver does almost all bass - standing in front of it you may even think it is doing nothing... :-P- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Thanks guys. Confidence restored; gonna tackle the LSi15s next weekend...
Fortress Plus build ---
Tweeter Network -
Clarity Cap CSA
Mundorf Mox Resistors
Jantzen Air Core
16 Awg Internal Wiring + Gold Disconnects
Midbass Network -
Clarity Cap CSA
Mundorf E Cap Bypassed by Clarity ESA
Jantzen Permite Core Inductors
Point to point, lexan substrate, aluminum terminal plate, insulated binding post- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Have to ask, I tried listening to your recordings just today, but each the Lsi9 and LsiC before and after tracks, and can not understand what is going on with the tracks.
I tried them several times, but realized eventually the levels are not very close at all, and it appears that some EQ or something is used on one or the other, to the point where one sounds very bass heavy and boomy and the other does not.
Are these issues with the recording, or level adjustments or something similar?
Maybe if someone else can give them a try and make sure it is not me or something I am doing?? -
Hello K_M and good afternoon to you sir. It has been some time since Trey (VR3) did these recordings. Some of the information available online and I'm sure some of the recordings have been compromised.
Trust me when I say that a crossover upgrade is worth more than an amplifier purchase or dedicated 20 amp line install. You don't know me from Adam and while I can respect that, the empirical evidence shows that the "Kid" knows what he is doing.
Perhaps Trey will address the recordings, maybe not. It has been a while, there could be nothing he could do to address the issues you are experiencing. I'd wait for him to chime in. He knows more than anybody about the recordings.
Patience in the meantime would serve you well.
I'll let Trey know about your inquiry.
I did this mod a long time ago. I think I payed around 500 bucks for the diy kit for my lsi15 and lsic. Man what a difference! Completely transformed those speakers from good to incredible.2 channel:
Theater:
Focal Aria 926,905,CC900, SVS PB ultra x2. Pioneer Elite SC85, Oppo BDP93, Panamax M5400PM, Minix neox6, Nordost Blue heaven LS power cables. -
So when we did the recordings, everything was done at the same distance/volume/song/etc.
This is important to note in that I guess the recordings really show off the volume/bass differences between stock and modified.
Amar Bose (RIP) once did a study about the loss realized when recording a recording. The recordings of the speakers sound the way they do due to what this study displayed. You will never be able to pick up the exact real life event with a microphone and there is considerable loss of quality/detail when recording an actual event and even more so when recording a recording. In fact, Mr Bose's study went to show that if you were to record the recording of the recording, it would eventually turn to static.
All I am getting across to you is that the recordings we did back in 2013 were more so just to highlight there were differences between stock and modified speakers, not what those modifications actually sounded like. It was more so the prove a point you can hear a difference and nothing more.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
"Sir " is a chick although the votes still out on that one... -
Oh Chit! My bad, I meant to say "Ma'am". I think. Am I being played with?
Whatever gender you are, please accept my apologies or accept my post at face value. Whatever the case, no offense intended.
Tom (I am a "Mr.")~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~ -
Tom (I am a "Mr.")
No, it is fine, and Sir, was a woman, but unlike most solo male acts in here, we are a married team, and at times have both posted and usually both read the forum.
Oddly, when we went back to the sound recordings, after having mentioned the issues, they changed sound wise quite a bit. Not sure what caused the issues or if they were something temporary.
Either way, the gross differences were gone, and the levels seemed quite similar.
Thanks again! -
I just looked this up and after reading about LSiC’s for sale with mods. I think the poor stock crossover is why I never put my LSiC into production. It just sounded dead. And while I know the recordings don’t do the mod justice, I can hear a difference and it seems to make the LSiC more dynamic.
Currently I’m running a Martin Logan 50xt as my center, it’s much larger compared to the LSiC and sounds much more lively, clear and transparent ( as in it just disappears in the dialog). Compared to the LSiC which sounded like muffled audio coming out of a box.
Is this mod worth taking a shot? Wish I could audition one. I’m quite happy with the ML but can the moded LSiC compete.
Can I also mod the LSi25? These are fine since they only reproduce ambient sounds for most HT viewing.- Living Room Music-2.0 Polk Legend L800 | McIntosh C70 | McIntosh MA5200 (Treble) | McIntosh MC452 (Bass) | Sublimeacoustic K231 Active xover | Denon DP-2500A | Denafrips Ares II | Belkin Soundform Connect | iPad Air USB to DAC
- Media Room Ht-7.2.6/13.1 (Atmos/Auro-3D) Polk LSiM707, LSiM706c, LSiM702 F/X [x4], height LSiM703 [x6], HSU VTF-15H MK2 Dual | Marantz AV8805A | Rotel RB-1590 (L/R) | Appollon NC500 11ch | Sony UBP-X800 | AppleTV 4K | JVC RS2100 | 150” Elite Screen Acoustic Pro UHD
- Game Room-5.1 Polk LSi25, LSiC, LSiF/X | Marantz SR7009 | AppleTV 4K | Xbox One S | Sony PS2, PS3 | Nintendo Wii | Gaming PC | Sony 75" LCD
- Master Bedroom Music-2.0 Totem Hawk | Marantz PM-10 | Marantz SA-10 | SONY PS-HX500
- Office-2.0 Ascend Acoustics Sierra LX, DSW microPRO3000 | Rotel RA-1570 | Marantz HD-CD1
- Daughter's Bedroom 1-2.0 TBD Martin Logan Forte | Roku TV
- Guest Room 2-2.0 Klipsch RP-600M | Martin Logan Forte
- Guest Room 3-3.0 Martin Logan Motion 40, 50XT | Onkyo TX-SR705 | Apple TV | Samsung 55" TV
- Guest Room 4-2.0 QAcoustics 3030i | Sansui AU-6900 | Topping DX7s | Sansui FR-1080 | Fire TV
- Maintenance: Pro-Ject VC-S Record Cleaning Machine
Muffled audio coming out of a box is exactly what I'm experiencing. I'm getting a weird upper bass peak that makes male voices sound nasally and muffled. Upping the crossover frequency to 150hz helped a little but not with clarity, just with the muffled sound.
Try a different center or try upgrading the speaker XO? -
The LSi series is a completely different speaker modified. The stock parts leave much to be desired
