Polk Audio SDA SRS 1.2TL Crossover Modification Thread
VR3
This one should be a lot of fun!
1) The speakers will be recorded stock!
2) Parts list is as follows -
Tweeter Network -Clarity Cap MR
Clarity Cap ESA
Mundorf Mox Resistors
Jantzen Inductors
Midbass/SDA Network -Clarity Cap ESA
Jantzen Inductors
Gimpod boards too
NL2 Connections for the SDA, Supra Rondo wire, Upgraded binding post
200 Hours or so of burn in
3) Record them modified!
This will be a fun project for sure!
Clarity Cap ESA
Jantzen Inductors
Jantzen Inductors
Gimpod boards too
Post edited by VR3 on
I'm all eyes on this one.
Good luck! -
Off to record these bad boys stock!
Still waiting on the inductors though to mod these!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Also make note of the changes in spatial properties between the stock and modified versions.Proud and loyal citizen of the Digital Domain and Solid State Country!
...in the results of this mod! (Especially since I own the pair to be modded)
ReaganSpeakers: Polk 1.2TL w/VR3 mods and Dreadnaught interconnects
Amplification: ARC Reference 110 w/KT150s; Cary Audio SLP-05 w/Ultimate Upgrade
Vinyl: VPI HW19 MK III (Heavily Modded); Origin Live Silver Tonearm; Hana ML Cart; Pete Riggle VTAF; VPI TNT Platter; SAMA; Iphono3
Digital: Aurender N100H; Benchmark DAC1 -
You are replacing all of the inductors too?Off to record these bad boys stock!
Still waiting on the inductors though to mod these!POLK SDA 2.3 TLS BOUGHT NEW IN 1990, Gimpod/Sonic Caps/Mills RDO-198
ONKYO HT RC-360 SONY BDP S590 TECHNICS SL BD-1 -
Yes, all board mounted and SDA- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Reagan
Have you spent much time with the 1.2's before the mods? I'm interested in a before and after comparison given that you're using, among other components, Clarity Cap MR's.
You're investing some serious coin!"Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer -
I've had the 1.2 TL's for about 10 years but am the original owner of SDA 1A's and 2'A's. I did the crossover upgrade on the 2A's and was quite pleased with the results. ReaganSpeakers: Polk 1.2TL w/VR3 mods and Dreadnaught interconnects
Cool - looking forward to your impressions."Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer -
Most definitely!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
I would have to say we captured the imaging capabilities of the SDA really well..- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Alright,
1.2TL recording posted - lets see if Soundcloud likes me tonight!
http://soundcloud.com/vr3mods/polk-audio-sda-srs-1-2tl-stock- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Sounds good to me.Who is singing?
Dan
Found it Thanks -
That is Millage Gilbert.
How do you feel we captured the SDA staging?- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
From what I can tell with my computer speakers it sounds real good.I wish I could give some more helpful feedback than that,but on these speakers just not possible.
Dan -
I have another 1.2TL coming for modifications that is what I would describe as "Balls Deep"
Clarity Cap MR on the entire tweeter network, all 12uf and .25uf caps and the midbass/SDA is all ESA.
I am a little pumped about this!!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Of the recording?
I have a lot of opinions but I want to hear everyones opinions first...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I am really thinking about putting the Clarity MR12's in my crossovers. I'm sure I will have to reconfigure my setup for them.
Maybe I just buy them and plan on doing a full point to point external crossover.. -
I have a brilliant idea to make the MR work and not even make it look like a mountain
Stay tuned!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
We *might* need more room!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
"Does this board make my caps look big?"
"I think we need a bigger board..."
Damn you Donkey Kong...stop throwing those barrels at me!"Some people find it easier to be conceited rather than correct."
"Unwad those panties and have a good time man. We're all here to help each other, no matter how it might appear." DSkip -
I can't wait to do the mod using the MR 12s... it is going to be SICK!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Tony should build a new board. You know, his original seems to have gotten a bit cramped.Good music, a good source, and good power can make SDA's sing. Tubes make them dance.
1.2TL with ESA/Jantzen - half way done!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
All wired up!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Who was it that said size doesn't matter?
Yeah those things are monsters! Three per crossover!!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
