US Amps Xterminator 1600.4 4-Channel Amp
Drenis
I have my amp listed locally and figured I would see if there was any interest here. This has been the best amp I've owned for the past couple years. It's been sitting for a few months now as I'm going a different direction whenever I get back into the car audio side of things.
Amp works flawlessly and there are no issues of which I am aware of. I was using it to power my 2 fronts and bridged subwoofer. All I ever needed.
Specs are as follows:
* Dynamic Power: 1600W
* RMS Power (2 Ohm): 200W x 4
* RMS Power (4 Ohm): 100W x 4
* 450 x 2 RMS @ 4 ohms
* Low level input sensitivity: 200mV to 6V
* Base EQ control at 45Hz: 0 to 12dB
* Platinum-plated connectors
* Dimensions (inches): 16.5(L)x2.5(H)x8.75(W)
* Signal to noise ratio: 95db
* Frequency response: 10hz to 50 Khz
* Bridgeable
* Bass eq control @ 45hz: 0 to 12db
* Top of the line Components
* Heat Management System
* Low pass, high pass, and all pass Crossover controls (adjustable @ 12 dB per octave)
* Level control
* Bass boost control
* Subsonic filter
* Line inputs
* Line output
* (3) 25A fuses
Pictures:
How's $150 + Shipping sound?
* Bridgeable
* Level control
* Subsonic filter
* Line inputs
* Line output
* (3) 25A fuses
Pictures:
Post edited by Drenis on
do you have pictures of the product i am sure it will get you more buyers
Bump!
Is this amp still for sale
Is not does anyone out there has one for sale.the xterminator series by us amps
tommytiptom2010 wrote: »Is this amp still for sale
From 7 years ago? -
He's an optimist........Political Correctness'.........defined
