Thiele-Small Parameters for MW6500 Drivers
Michael8it
I have some spare parts laying around and am interested in building a center channel speaker using these old components. Does anyone know the Thiele-Small parameters for MW6500 drivers? These would be needed to know what size port to put in the box.
The parts I would like to use:
1 Peerless Tweeter
2 MW6500 drivers
RTA12 or 12B (top) Crossover.
Due to size requirements, the box need to be ported, not sealed, which is why I need the specs.
Thanks!
1 Peerless Tweeter
2 MW6500 drivers
Thanks!
Carver C-1, M-500 MKII, Yamaha HTR-5835, Polk RTA 12BM's (M-for mod'd).
Post edited by Michael8it on
Michael8it wrote: »I have some spare parts laying around and am interested in building a center channel speaker using these old components. Does anyone know the Thiele-Small parameters for MW6500 drivers? These would be needed to know what size port to put in the box.
1 Peerless Tweeter
2 MW6500 drivers
Thanks!
Driver: MW 6500 Driver's model #.
Brand: Polk Driver's brand name.
Fs: 31.0000 Hz (Free air resonance)
Vas: 2.6486 ft^3 (Compliance volume)
Qts: 0.2190 Total Q
Qms: 1.3000 Mechanical Q
Qes: 0.2640 Electrical Q
Sd: 0.0130 M^2 (Piston area)
Xmax: 3.1800 mm (Cone excursion, linear)
Revc: 6.5000 ohms (DC resistance)
Znom: 8.0000 ohms (Nominal impedance)
Pmax: 35.0000 watts maximum rated power
Driver: MW 6501 Driver's model #.
Vas: 2.7545 ft^3 (Compliance volume)
Qts: 0.2790 Total Q
Qms: 1.4700 Mechanical Q
Qes: 0.3440 Electrical Q
Revc: 7.7500 ohms (DC resistance)
Driver: MW 6502 Driver's model #.
Fs: 44.0000 Hz (Free air resonance)
Vas: 1.2360 ft^3 (Compliance volume)
Qts: 0.2790 Total Q
Qms: 1.9700 Mechanical Q
Qes: 0.3250 Electrical Q
Revc: 3.5200 ohms (DC resistance)
Znom: 4.0000 ohms (Nominal impedance)
Driver: MW 6503 Driver's model #.
Fs: 29.8600 Hz (Free air resonance)
Vas: 3.0017 ft^3 (Compliance volume)
Qts: 0.3100 Total Q
Qms: 1.7680 Mechanical Q
Qes: 0.3760 Electrical Q
Revc: 6.5400 ohms (DC resistance)
Driver: MW 6517
BrandL Polk Audio
* Size / Type = 6.50" treater paper cone woofer
* SPL = 91 db @ 1w/1m
* Wattage = 125 Watts RMS / 250 Watts Peak
* Treated cone woofer, rubber surround
* Response = 40 Hz. to 10 kHz.
* Weight = Right a 4 pound ea.
* Magnet = UnShielded
* VC = 1" ( 25 mm)
* Ohms = 4 ohms
* f(s) - 55 Hz.
* Q(ms) - 7.261
* V(as) - 14.60 liters ( 0.516 cf. )
* n(0) - 5.02%
* M(ms) - 18.38 grams
* R(e) - 1.86 Ohms
* Q(es) - 0.048
* SPL - 92 dB @ 1W/1m
* C(ms) - 0.44 mm/N
* Z(max) - 281.50 Ohms
* Q(ts) - 0.048
* L(e) - 31.08 mH
1 Driver Type Q BL Compliance DC Resistance Fs
3 MW 6501 1.470 5.96 N 3.250 E - 3N/M 7.750 Ohms 31 Hertz
4 MW 6502 1.970 5.16 N 1.470 E - 3N/M 3.520 Ohms 44 Hertz
5 MW 6503 1.820 5.24 N 3.550 E - 3N/M 6.540 Ohms 29 Hertz
6 MW 6509 2.100 4.57 N 3.540 E - 3N/M 8.970 Ohms 30 Hertz
7 MW 6510 1.390 6.32 N 3.410 E - 3N/M 6.570 Ohms 31 Hertz
8 MW 6511 1.405 4.34 N 3.496 E - 3N/M 3.130 Ohms 29 Hertz
9 MW 6512 1.905 4.99 N 1.588 E - 3N/M 3.466 Ohms 40 HertzHome Theater/2 Channel:
dhsspeakerservice.com/
