SDA non common ground amp question
hoosier21
Are 5 channel amps "common ground" amps?
I was thinking of using a 5 ch amp to bi amp my SDA 2.3tl's, use one channel for the right HF input and one channel for the LF input and the same for the left speaker, this will use 4 channels of the 5. Thanks for your time.
Dodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
Post edited by hoosier21 on
Not all, but MOST modern amps, are of common ground design. Even the HT five channel models. If you are uncertain about your amp, contact it's manufacturer, and ask them.
Great idea to use the amp in that fashion.
George Grand (of the Jersey Grand's)
