Universal 10" sloted comp box.
logo896
For only 45 dollars + shipping.
This listing is for a high performance single 10" subwoofer.Item is in good condition id rate it a conservative 7 out of 10 as it has some signs of wear but works 100%. It is made of extra thick MDF and slotted for extra bass. It previously had a JL audio W7 in it and, so I am not aware of any 10" subwoofer on the marker that wont fit this box. Simply moving from a traditional sealed subwoofer box to this one will give you double the volume. Costing several hundred dollars when new, you would be hard pressed to find a box better than this one for even 100 dollars.
measuring 13 inches tall x 16 inches deep and 20 inches wide.
pay pal preferred,
Logan
pay pal preferred,
Logan
Post edited by logo896 on
How is this 3-piece grill secured to the box itself??2008 Nissan Altima
Kenwood DNX 5140
Arc Audio IDX and XEQ
Polk Audio SR6500 active and SR124-dvc sealed
Polk Audio PA500.4 and PA1200.1 -
They are snugly secured with just pressure. They have drill points behind them and pull out. Even with the w7 fully pounding it never had a vibration or moved or anything. Its a great box, but I have to fit kiddy stuff in my little trunk so i moved to a smaller subwoofer and sealed box. Feel free to pm with any other questions. I have never updated my sales on here, but i have a solid sales rating under logo896 on audiogon.
bump
