Mono, 2, 4, 5 ch amps, subs, speakers: Polk Audio, Infinity, JVC....
Vital
Vital Posts: 747
edited January 2011 in Garage Sale
All these items were used by me at one point or another, some things were in my house for over 2 years just taking up space, some came off the car just 2 days ago.
All prices except for Polk Audio db1212 include FedEx delivery. If for whatever reason you don't want me to use FedEx let me know.
Paypal fees are NOT included.
All items are used (installed and then unintalled lol) so some small imperfections/blemishes could be expected but nothing major. I will mention all "more then small scuffs" on item's description.
Local pick up is welcomed. I'm often in Brooklyn, NY/Staten Island, NY/Elizabeth and Newark, NJ area.
Some items come with box/manual, some only with manual, some without anything it originally came with. See this pic for items with boxes.
1. Polk Audio PA600.1 - $170
300 watts RMS x 1 at 4 ohms (400 watts RMS x 1 at 2 ohms)
600 watts RMS x 1 at 1 ohm (one-ohm stable)
CEA-2006 compliant Class D amp with MOSFET output and power supply
variable low-pass filter (30-250 Hz, 12 dB/octave)
selectable bass boost(8 dB) at 40 Hz subsonic filter (30 Hz, 24 dB/octave) preamp outputs output phase switch optional wired remote volume control LED/fan connector powers optional external fan and LEDs
fuse rating: 30A x 2
4-gauge power and ground leads recommended
13-3/4"W x 2-9/16"H x 10-5/16"D
2. Polk Audio PA200.4 - $80
45 watts RMS x 4 at 4 ohms (50 watts RMS x 4 at 2 ohms)
100 watts RMS x 2 at 4 ohms (4-ohm stable in bridged mode)
2-, 3-, or 4-channel output
CEA-2006 compliant MOSFET
output and power supply selectable high- and low-pass filters (100 Hz, 12 dB/octave)
selectable bass boost (8 dB) at 40 Hz
preamp outputs LED/fan connector powers optional external fan and LEDs fuse rating: 30A x 1
12-1/2"W x 2-9/16"H x 10-5/16"D
3. JVC KS-AX4750 - $65
Shaun Palmer Signature Series
Bridgeable 2-Channel Power Amplifier
Continuous Power (RMS) of 100W per Channel into 4 Ohms
Frequency Response: 20Hz-20kHz
Max. Power 560 Watts Mono
2 Ohm Stable Operation (2-8 Ohm Allowable)
Bass Boost Control
Variable Input Level Control
Crossover Frequency: 80Hz
HPF/LPF/OFF Swtich
Gold-Plated Large Input Terminal and RCA Jack
Over-Temperature Protection
Overload Protection
Short Circuit Protection
DC Offset Protection
Anti-pop Circuit
Signal/Noise Ratio: 100dB
Bass Boost Frequency: 50Hz
Line Input Level: 0.3-5V
2008 Nissan Altima
Kenwood DNX 5140
Arc Audio IDX and XEQ
Polk Audio SR6500 active and SR124-dvc sealed
Polk Audio PA500.4 and PA1200.1
Post edited by Vital on
  • Vital
    Vital Posts: 747
    edited December 2010
    4.EXTREME XA-6004 - $50
    Max Power 600W RMS Power Output @ 4 ohms: 60 Watts x 4
    RMS Power Output @ 2 ohms: 75 Watts x 4
    CEA-2006 Compliant
    Signal to Noise Ratio: -75 dBA (reference 1 Watt into 4 ohms)
    Damping Factor: >75
    Input Sensitivity: 200mV - 4V
    Crossover Type: 2-way Variable 12dB Bass EQ Switched, +0/8dB @ 45Hz High-speed MOSFET power supplies Complimentary bipolar transistor outputs Rear bridged and front stereo or variations 2 ohm stereo stable/4 ohm mono stable Built-in 2-way variable crossovers +8 dB switchable bass boost
    GROUND SCREW IS MISSING, 2 out of 4 MOUNTING TABS ARE BENT. Can easily be bent back with a pair of pliers. I can even do it for you if you wish.
    5. Infinity 5350a - $170
    5-channel car amplifier
    50 watts RMS x 4 + 150 watts RMS x 1 at 4 ohms
    60 watts RMS x 4 + 300 watts RMS x 1 at 2 ohms
    120 watts RMS x 2 at 4-ohms + 150 watts RMS x 1 at 4 ohms in 3-channel mode
    CEA-2006 compliant
    variable high- and low-pass filters (32-320 Hz, 12 dB/octave)
    variable bass boost (0-6 dB at 50 Hz)
    Class AB 4-channel amp with Class D mono sub channel MOSFET power supply
    3 sets of preamp-level inputs
    fuse rating: 40A x 2
    17-1/16"W x 2-11/16"H x 9"D
    2008 Nissan Altima
    Kenwood DNX 5140
  • Vital
    Vital Posts: 747
    6. Polk db1212 - $120 (LOCAL PICK UP!! shipping cost will kill any desire to buy it lol)
    ported enclosure with one 12" db Series subwoofer
    3/4" MDF construction with front-panel ABS trim
    polypropylene woofer with Santoprene rubber surround 2-ohm impedance
    frequency response: 26-200 Hz
    power handling: 50-360 watts RMS (720 watts peak power)
    sensitivity: 97 dB
    17-1/4"W x 14-3/4"H x 18-11/16"D1 x 15-11/16"D2
    THERE's A CARPET RIP ON ONE OF THE CORNER, see in pics below. Obviously doesn't effect performance.
    7.Infinity 1052w - $40
    10" subwoofer with dual 4-ohm voice coils
    polypropylene cone with large-roll rubber surround
    innovative basket design minimizes depth progressive spider design for excellent cone control
    power range: 60-250 watts RMS (125 watts per voice coil)
    peak power handling: 1,000 watts
    frequency response: 25-400 Hz
    sensitivity: 91 dB
    top-mount depth: 4-9/16"
    sealed box volume: 0.75 cu. ft.
    ported box volume: 1.75 cu. ft.
    2008 Nissan Altima
    Kenwood DNX 5140
  • Vital
    Vital Posts: 747
    8. Kicker SSMB8 - $60
    spring-loaded nickel-plated terminals accept heavy-gauge speaker wire
    free-air capability
    175 watts RMS
    impendence: 4 ohms
    maximum peak power 350 watts
    frequency response 30-500 Hz
    sensitivity 89 dB
    flush-mount depth 2-5/16
    One of them is still literally brand new. I installed one in my rear door but door panel wasn't fitting back on so second one was never installed. Literally haven't seen any power yet.
    9. Polk Audio MMC690 - $90
    3-way 6"x9" speakers (pair)
    1-1/4" silk/polymer dome tweeter and 3/4" silk supertweeter
    outboard 2-way crossover
    dual nickel-plated terminals for biamping
    recommended power range: 10-100 watts RMS
    peak power handling: 200 watts
    frequency response: 33-25,000 Hz
    sensitivity: 91 dB
    top mount depth: 3-1/4"
    Wires from x-overs to speakers were cut and extended by me with 16g Kicker hyperflex speaker wire so i could have those x-overs where i wanted them, not where length of the wire allowed. Will come with that same Kicker wire connected, you can always cut it to make it shorter if you want to.
    2008 Nissan Altima
    Kenwood DNX 5140
  • Vital
    Vital Posts: 747
    Here's 2 items that are "below normal"
    10. Kenwood KGC-4042A - $25
    The KGC-4042A offers three sets of RCA preamp outputs.
    Two full range sets are controlled by a fader to provide dual-amp balancing, even with a head unit that has only one pair of pre-outs.
    The fader's also ideal for dialing in just the right amount of rear-fill.
    The third set is a low-pass subwoofer output with level control. Whenever this sub output is in use, the EQ engages high-pass crossovers on the front and rear channels. That's like having a free electronic crossover packaged with your equalizer — a pretty sweet deal!
    two sets of full-range outputs with high-pass filter that engages when subwoofer output is in use. subwoofer output has adjustable level control (up to +10 dB).
    adjustable subwoofer crossover range (30-150 Hz)
    dual illumination.
    signal-to-noise ratio 100 dB
    THD 0.01%
    3-1/2"W x 1"H x 5-3/4"D
    It's a fully operational unit, actually one of the best in it's category (look it up) but power wire was accidentally cut when taking it out of my old car. Taking the car apart just to get that wire was an overkill so i never bothered. All you need is another wire harness and u're good to go. I'm sure Kenwood has them, maybe even for free as a curtesy.
    11. Polk Audio db6501 - $40
    power range: 10-100 watts RMS (300 watts peak power)
    frequency response: 35-23,000 Hz
    sensitivity: 92 dB
    impendence: 4 ohms
    1. Will come in a box from coax set
    2. You get exactly what u see in the pics. There's no manual, mounting adapters, mounting tweet cups... Does come with brand new grills thou.
    3. dust cap on one of the woofers flew off. Does NOT effect functionality. Both woofers play the same.
    4. One of the resistors in the crossover broke off from x-over being installed in the door and was re-soldered back. Plays fine since but you might wanna be aware of that.
    2008 Nissan Altima
    Kenwood DNX 5140
  • Vital
    Vital Posts: 747
    Kenwood eq is sold.
    2008 Nissan Altima
    Kenwood DNX 5140
  • Vital
    Vital Posts: 747
    Kicker SSMB8 is sold.
    2008 Nissan Altima
    Kenwood DNX 5140
  • kawizx9r
    kawizx9r Posts: 5,150
    Had my eye on the Polk PA600.1 since you've posted this but I don't know if it'll be much of an upgrade over my 360.2 (360w rms@4ohms). I'm powering a 12" SVC Mobile Monitor sub.
    What do you think? Or should I wait and get a 1200.1, be honest :tongue:
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • Vital
    Vital Posts: 747
    Not sure what 360.2 is (Polk??) but if it's pushing 360w @ 4 ohms then getting a sub that does 300 rms @ 4 ohms will actually be a downgrade lol. That's strictly talking numbers,if your 360.2 is Pyle or Boss (again, i don't know which amp u're talking about) then getting Polk 600.1 (that does "less" rms) might actually be an uprgade.
    And even with that, if i were u i'd get 1200.1 and another MM sub lol. :) If memory serves me right MMs are around 400rms while 1200.1 goes down to 1200rms @ 1ohm and 800 @ 2 ohms - just right for 2 MM subs.
    2008 Nissan Altima
    Kenwood DNX 5140
  • kawizx9r
    Vital wrote: »
    LOL
    Sorry, thought you'd see it in my sig. It's a JL Audio amp.
    I only plan on running a single 12" MM due to space (and I don't want the added weight). The sub is rated at 425w rms, and at 4ohms the 1200.1 will be right there with the power I need.
    I've heard great things about Polk's amps and surely understand 'numbers' aren't everything but was wondering if the 600 would be much of an upgrade. I'll just hold out and wait for a 1200.
    Thanks again and goodluck with the sale!
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • PerfectCreature
    PerfectCreature Posts: 1,456
    The 1200 will put out as much as the 600 will at 4 ohms.
    The Polk would be a better option due to its versatility.
    Hey, check your post over at diyma, interested in the crossover and tweets.
    Receiver
    Harman Kardon HK 3490
    Speakers
    Polk Audio Monitor 50s
    Subwoofer
    Klipsch KSW-100
    Cables
    AudioQuest Rocket 33s 10ft
    AudioQuest Optilink1 2m
    AudioQuest Alpha-Snake 25ft Interconnect
    AudioQuest HDMI-1 2m
    Alienware X51 R2
    PS4
    Samsung Smart TV 40" 1080p 3D
  • Vital
    Vital Posts: 747
    Polk MMC690 is sold!
    2008 Nissan Altima
    Kenwood DNX 5140
  • Vital
    Vital Posts: 747
    Polk db6501 is sold!
    2008 Nissan Altima
    Kenwood DNX 5140
  • Vital
    Vital Posts: 747
    btw i'm looking for Polk MM6501, Tru SSLD6 and can even use another SR124-dvc so if anyone has any of these and wants to trade for anything i have i def can trade.
    2008 Nissan Altima
    Kenwood DNX 5140
  • Vital
    Vital Posts: 747
    Infinity 5 channel is sold!
    2008 Nissan Altima
    Kenwood DNX 5140
  • Vital
    Vital Posts: 747
    Infinity 1052w is sold!
    2008 Nissan Altima
    Kenwood DNX 5140
  • Vital
    Vital Posts: 747
    edited January 2011
    EXTREME XA-6004 is sold!!!
    2008 Nissan Altima
    Kenwood DNX 5140
  • Outfitter03
    Outfitter03 Posts: 563
    edited January 2011
    Spam reported.
  • Vital
    Vital Posts: 747
    edited January 2011
    Most of POLK AUDIO is still available!!! (and JVC amp :) )
    2008 Nissan Altima
    Kenwood DNX 5140
