yamaha rx-v1
joe logston
joe logston Posts: 882
edited February 28 in Clubhouse Archives
the yamaha rx-v1 is going to be replaced by the yamaha rx-z1 the yamaha rx-v1 has a duell 44 bit prossceser its is the best prossceser on the planet right now all the 2nd. best are 32bits the new rx-z1 that are replaceing the rx-v1 have 32 bits prosscesers so if you whant the best you better hunt them down now before there all gone. wend muti-channel autio gets going thats muti-sacd & dvd-autio, that 44 bit prossceser will be the ultimate. the rx-v1 has 8 channels ,2 mains, 2 surounds,1 front center, 1 rear center, 2 front effects. plus 3 lfe sub outs. you will problely use witch i do the enhanced mold in dolby digital ex,or dts es will be all 8 channels , the yamaha goes with polks real good
thanks, joe
. rt-7 mains
rt-20p surounds
cs-400i front center
cs-350 ls rear center
2 energy take 5, efects
2- psw-650 , subs
1- 15" audiosource sub
lets all go to the next ces.
Post edited by RyanC_Masimo on
