Low cost good amp for db5251's
xj4094dg
Hello Car Audio Forum Gurus.
I haven't done any Car Audio in years and don't know anything anymore. I bought a pair of db5251's and need a low cost amp.
Something good, but no huge budget ($100.00 or less?). I got a new pair of db5251's from Polk for $79.00 (using 100 Polk bucks).
Suggestions welcome.
Thanks in advance.
Thanks in advance.
"The good thing about science is that it's true whether or not you believe in it." Neil deGrasse Tyson.
Post edited by xj4094dg on
no, not a huge budget, good luck. i think walmart sells amps for $100. who'd want that though. crutchfield actually has 3 amps under 100 rite now. i'd act. if i had 2 choose i'd say RF. but can't beat cadence outlet. cadencesound.com. proly get a 4channel for that price. i want some polk buksPolk MM6501 kick panels, Eclipse cd7200mkll and SW9122 Bomb Box, Cadence A4, A7, CAP5, JL8W3V3
I know this is 60 more than your budget but they would make those db's sound so good.
http://www.sonicelectronix.com/item_13578_Polk+Audio+PA200.4.htmlTV: Philips 42" LCD 1080p
Front Speakers: Polk Audio RT800i
Center Speaker: Polk Audio CS1
Surround Speakers: Polk Audio R50's powered of Denon AVR
Subwoofer: Polk Audio DSW pro500
AVR: Denon 3801
DVD Player: Denon DVM 745 upscale 1080p
Sat: Directtv HD 10
Front Speakers Amp: Rotel RB 890
Center Speaker amp: Rotel 970 BX -
Thanks greg2350 and cadenceclipse.
Again, I don't know S about car audio, many $ have been spent on the home system, but I don't spend a lot of time in the Jag so I don't want to spend a huge amount there.
I'm checking out all your suggestions though and appreciate your input. I love this forum....
Do either of you know anything about this alpine amp: Alpine MRP-F240 ?
Thanks again.
BTW, polk sent me an email to take part in a survey one day and gave me the POLK BUCKS for my time."The good thing about science is that it's true whether or not you believe in it." Neil deGrasse Tyson. -
yeah, its an alpine, so can't b that bad.
polk amps on sale at crutchfield now. stil say cadence..
word, was that survey for home audio?Polk MM6501 kick panels, Eclipse cd7200mkll and SW9122 Bomb Box, Cadence A4, A7, CAP5, JL8W3V3 -
cadenceclipse wrote: »yeah, its an alpine, so can't b that bad.
The survey was regarding the new look of the website. I told them it looked like they were selling lots of outdoor and HT in a box at first glance. I thought the site examples they showed me were kinda cheesy."The good thing about science is that it's true whether or not you believe in it." Neil deGrasse Tyson. -
and they gave u 100 buks?? sweet what u want 2 know about amp? think u want 2 know about a diff. amp..Polk MM6501 kick panels, Eclipse cd7200mkll and SW9122 Bomb Box, Cadence A4, A7, CAP5, JL8W3V3
OK. I found this amp: Alpine MRP-F240 V-Power Car Amplifier. 64.99.
Specs:
Power Output: RMS Continuous Power (at 14.4V, 20 Hz to
20kHz)
Per channel into 4 ohms (0.08% THD) ... MRP-F240: 40Wx4
MRP-T220: 50Wx2
Per channel into 2 ohms (0.3% THD) ..... MRP-F240: 50Wx4
MRP-T220: 70Wx2
Bridged into 4 ohms (0.3% THD) ......... MRP-F240: 100Wx2
MRP-T220: 140Wx1
Total MAX Power .......................................... MRP-F240: 360W
MRP-T220: 250W
Frequency Response ................... 10 Hz to 50 kHz (+0, 1 dB)
Signal-to-Noise Ratio
(referenced to rated power) ........................................ 100 dBA
Slew factor ........................................................ Greater than 5
Input Sensitivity (for rated power
output) ........................ 200mV to 4.0V (1.0V at center detent)
Input Impedance ................................................... 10k ohms<
Speaker Impedance ............................... 4 or 2 ohms (Stereo),
4 ohms (Bridged)
Active Dividing Network Frequency and
Slope .................................................. 80 Hz, 18 dB per octave
Bass EQ ........................ MRP-F240: 50Hz, 0 to +12 dB (CH3/4)
MRP-T220: 50Hz, 0 to +12 dB (CH1/2)
Power Requirement .................. 11 16V DC Negative Ground
Dimensions (W x H x D)
MRP-F240 ................................ 266mm x 60mm x 242mm
(10-7/16" x 2-3/8" x 9-1/2")
MRP-T220 ................................ 206mm x 60mm x 242mm
(8-1/8" x 2-3/8" x 9-1/2")
What do you think? Will this work? Again, its within budget.
Thanks.:cool:"The good thing about science is that it's true whether or not you believe in it." Neil deGrasse Tyson.
