Denon Power amps- Common Ground?
gcstokes1
Opportunity knocks on a Denon POA-1500 . Nice unit. Is it common ground? Anyone have any thoughts on this amp?
G
G
Post edited by gcstokes1 on
Yes it is common ground. I have one and really like it. Do be prepared to replace the bulbs, (lights for the meters) or disconnect them if you so desire.
I have a pic somewhere of the insides I'll try to find. -
Thanks. I am torn between this and a Sonance 2120 (120 WPC) to run a pair of CRS+, using a Kenwood KA-7300 as a pre-amp. there is also a PRA 1000 available, but not sure I can afford both. Perhaps the Pra-1000 and the sonance??? So many decision. What are you using for a pre?
G -
Denon PRA-1500
Here is a picture of the "Guts".
Having never heard or owned a Sonance, I can't comment on that piece.
At about 50 lbs the Denon it a beast. I think your SDA-CRS+ are 6 ohms, so the POA-1500 will push them with ease at 195 watts per channel RMS if I recall correctly. Enjoy G.:) -
Wow! too bad the transformer is so small.....
I have been trying to find some info on the PRA 1000. All of the specs on Denon I have seen are pretty impressive. I just sold a PMA-750 integrated. Very nice unit, but am looking for the right combo for the CRS+. I had a Sonance pass through here for a few days a while ago, and was quite impressed. -
I "might" be picking up a Denon POA-2400....is it common ground?--Gary--
I'd go with the Denon, much better build quality and bonus meters!
Sonance 2120 / Denon POA-1500
/ Denon POA-1500.jpg
Regards,
Mike
