blown tweeters?
Mossy
Mossy Posts: 21
edited May 2003 in Troubleshooting
If you have a blown tweeter...should it still have some kind of sound coming out of it? My right sda tweeter is not working but my other tweeter in the same cabinet is working? Could this be that the wire has come loose inside the cabinet going to the tweeter? I have no sound at all coming from the sda tweeter. Please give me some direction on what to do about this. Thanks.
Post edited by Mossy on
    VR3 Posts: 28,042
    edited May 2003
    If its blown, the tweeter will crackle, pop, etc. If its making no noise, check the connection.
  • Mossy
    Mossy Posts: 21
    edited May 2003
    That is what I was thinking...thanks for the advice.
  • RuSsMaN
    RuSsMaN Posts: 17,987
    edited May 2003
    If the tweeter is blown, it won't make any noise, especially along the rice-crispy variety.
    Cheers,
    Russ
