Subwoofer Driver Replacement
weiser
weiser Posts: 55
edited April 2003 in Troubleshooting
How does one know when to replace a subwoofer driver? What I mean by this is if you have a sub that plays low and has no physical anomolies does the driver still wear out over time. I have a 15 yr. M&K that plays fine but am considering replacing the driver because of age. I find that playing deep notes the rubber surround begins to make noise but if I put a finger on the surround it seems to go away. What would cause this? or is it just limitations of the sub or age?
Any info would be appreciated!
Also, I am told that I should replace the driver with another M&K driver of same type! Is this true or could I use others?
JVC AV48WP30 Widescreen TV
Marantz SR6200 Receiver
Panasonic RP-82 DVD
Sony SAT-A50 DSS DD Receiver
Sonic Frontiers Anthem Amp 1
Tara Labs-Axiom Interconnects
Tara Labs Digital 75 Co-axial
Kinima HiG2 Mains
Polk CS400i Main Center
Kinima KC2 Rear Center
Polk FX300i Rears
Polk PSW 350 LFE Sub
M&K V-3B Mains Sub
M&K V-2B Mains Sub
M&K LP-1S High Pass Filter
Ultralink Bi-wiring Thru
AR Pro Series Interconnects
Marantz RC2000 MKii Remote
Post edited by weiser on
  • gidrah
    gidrah Posts: 3,049
    edited April 2003
    If I were to replace a driver, I'd do it with one from the manufacturer.
    All components loosen over time. Subwoofers are notorious for this. Tighten everything back down. After 15 yrs you may need to use a little wood putty or a toothpick. Magnets do loose their flux over time, but I don't think this is your problem.
    Good luck!
    Make it Funky! :)
