DIY Shielded power cable
sTiLlLeArNiNg
sTiLlLeArNiNg Posts: 805
edited November 2009 in DIY, Mods & Tweaks
Hello again everyone! :)
I finally got around to finishing my shielded power cable's so i thought i would share ;) I made 3 set's :eek: 1 for my AVR, 1 for my xpa5 and 1 for my LCD :cool:
Tools used: Wire cutter/stripper, box cutter, helping hand's, lighter, phillip's screw driver, soldering iron and a heat gun
Please note that whenever building cable's try to make them directional, for example: Most cable's have text on the sleeve so what i like to do is have the signal path following the text ;) So in this case i started the build on the male IEC end with the text flowing to the female end. Sorry i'm not very good at explaining thing's but i hope it help's :o
Part's used: Belden 83802 shielded power cable, Oyaide style IEC connector's (c079 & p079), 16g tinned MIL spec hook up wire, Dayton 4% silver solder, 3/8" Techflex and lastly 1/2" 3:1 heatshrink. All Component's have been deep cryo treated for improved charecteristic's. I started out with 15ft of the Belden and cut to length as needed.
Some pic's of the process, they are pretty self explanatory but if you have any question's just ask :)
Thank's for looking :)
Media Room 7.1
Sharp lc37d64u | Sanus vmsab-03 | Sonax ZX8680 | Yamaha htr-6290b | Emotiva xpa1 x 2 & xpa5 | RTiA 9 & 7 | CSiA 6 | FXiA 6 | Sanus NF30B-03 | Velodyne dls-3750r | Dual 505-3 m97xe | Monster avs2000/hts5100
HTPC
Intel e5300 | Asus p5q DLX | LG ch08 BD | OCZ 4g reaper2 | WD 1TB | Sapphire 4890 VaporX 1g | Asus Xonar HDAV 1.3 | OCZ modXtreme 700w | Antec Fusion remote MAX
A fool and his money are easily parted
I don't drink Koolaid
Need some cable's? Just ask :)
Post edited by sTiLlLeArNiNg on
  • george daniel
    george daniel Posts: 12,096
    Nice work again sir,,I would be interested in how you perceive the performance/sound change. One thing,,what is the short piece of green wire for?
  • fbm211
    fbm211 Posts: 1,488
    I think the green wire is for the shield connection.At the IEC end if Im not mistaken.
    SDA-2BTL with custom IC
    Harman Kardon T-55c TT
    DH LABS REVELATIONS ICs-amps
    Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    So how does it sound?
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • kawizx9r
    kawizx9r Posts: 5,150
    disneyjoe7 wrote: »
    Would also like to know of any noticeable improvements :D
    I'm contemplating making my own power cables, utilizing this IEC and one of these plugs from Marinco. Also thought about their hospital grade version here.
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • george daniel
    disneyjoe7 wrote: »
    Hey,, I've already asked that Steve,, are you trying to run your post count up before the holidays? ;):)
  • sTiLlLeArNiNg
    Thank you george! It was VERY fun to make my own cable's and i will enjoy making more in the future ;) I will answer the green wire & sound Q further down in this post since a couple people asked :o
    fbm211 wrote: »
    The green wire is indeed for the shield, it "power's up" the shield lol
    This particular Belden cable is double shielded with 100% coverage using both a mylar foil and a copper braid, but for added "performance" i had them drain to the ground in the wall circuit :)
    You want the EFI/RFI draining to the wall circuit, not into the equipment. Therefore it is on the male end ;)
    disneyjoe7 wrote: »
    TBH i have less than 50hrs on the cable set plus my audiophile "lingo" is lacking lol but i'll give 'er a go :o
    These were noticed immediately after installation: The cable's are very "clear" and "transparent". I have noticed a lower "nosie floor" and since swapping over, my LCD also has slightly better picture quality! In short i don't think they add or remove anything from the sound just that they clean thing's up and as a result make thing's more audible....
    :o
    kawizx9r wrote: »
    I answered the sound quality Q in the response above your post :) Those Marinco connector's are basically the same thing as the one's i used save for a few difference's, they are highly regarded connector's and will work well. Use hospital grade part's whenever possible ;) What are you planning to use as cable?
    My next DIY jobbie is to bring the 20a service in my kitchen to my media room with a six outlet "break out" box ;) I think i'll get a really nice improvement when i do this because i came to find out that ALL of the bedroom outlet's (3 bedroom's & minimum 4 outlet's per room) run off of the same 15a breaker!! DOH!! :mad:
    There are two 20a breaker's in my panel :D One 20a breaker is for the fridge/stove and the other is not powering anything :D I just need to figure out what exactly i need so i can git 'r done :cool: Anyone with ideas of how i can go about doing this safely please let me know!
    Thank you :D
    Media Room 7.1
    HTPC
  • kawizx9r
    Not sure when, it's not on my must-have's list but I'll get around to it unless you want to build them for me? :p
    Now that I think about it, I'd attach a ferrite clamp on the female end of a cord. What do you think?
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • sTiLlLeArNiNg
    kawizx9r wrote: »
    I can build you a set if you like, not a problem :) Let me know what length/s you need and if you want shielded/non-shielded, cryod /non-cryod, 2 conductor wire/3 conductor wire/Star quad, standard connector's or Oyaide/Wattgate style, flex tech or no tech flex, etc, etc.... We can work out a price ;)
    Ferrite's have no place on a cable IMHO. I truly think they can change the "harmonic's" in certain application's. Manufacturer's/OEM's use them because they don't want to spend the cash on the proper shielded cable's ;)
    Media Room 7.1
    HTPC
  • kawizx9r
    If you're talking ferrites on shielded cables, then yea that's a bit of a waste but it can help unshielded/poorly shielded cables at the source of output. That's just stuff I learned at in class couple years ago, measuring noise/etc. on a power cable with/without the use of a ferrite clamp and the differences between cables as stated above.
    I'd like to grab something for my amp, shielded since there are several components/wires around the damn thing but the plug looks to be a bit too big to be used on my amp.
    Also, I'd consider one for the subwoofer....non-shielded is ok but the cable doesn't have a ground although it is polarized.
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • TECHNOKID
    TECHNOKID Posts: 4,298
    [QUOTE...Now that I think about it, I'd attach a ferrite clamp on the female end of a cord. What do you think?[/QUOTE]For the LCD it would worthwhile but useless for audio, right?
    DARE TO SOAR:
    “Your attitude, almost always determine your altitude in life” ;)
  • sTiLlLeArNiNg
    I will state again: IMHO a ferrite core has no place on a cable. If you have/use the proper cable the need for a ferrite core is NOT required ;)
    Freddy if you are serious about the cable's send me a detailed PM with what you want/need and i'll get back to you ASAP and we can work something out :)
    Media Room 7.1
    HTPC
  • kawizx9r
    Yeah I am, but not yet since I don't have extra funds otherwise I'd be doing it myself. I do get where you'd use the Dayton silver solder because the temperatures here aren't a concern, I don't often build cables at all so it's what I just happen to have around. :D
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • sTiLlLeArNiNg
    Why buy something if you have it laying around already? ;)
    If you or anyone want cable's just shoot me a PM and let me know what you want/need. Being partially disabled leave's me quite a bit of "free" time ;) So i can provide pretty much anything you/anyone need with good turn around time :)
    Media Room 7.1
    HTPC
  • george daniel
    You know,,I really enjoyed building/making power cables also.My wife helped me make the Bob Crump DIY cable, similar to yours,,different grade/type Belden. I think I'm gonna try to make a few using the grade of Belden that you have.If you would,,please post your impression in this thread,,say,,in about 30 days if you don't mind.One question,, could you have connected the "drain" to the ground directly?Thanks in advance,,and enjoy the cables.:)
    BTW-- can you post where/who you bought the cable and component paarts from?
  • disneyjoe7
    Where did you got that wire?
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • TECHNOKID
    FOI, I wonder if full shielding (using metal shielded plug) would be benificial for such project versus partial shielding (which is applied here by mean of a ground plug instead of a fully shielded plug)? I am asking because dealing with home audio systems might be a little different then the typical set-up we had in the military. The goal is still the same, trying to avoid any RF in and/or out but who knows, maybe some I don't see here?
    Now, from what I am reading, you are connecting your shield at the plug ground alone in order for the shield to act as an antenna thus returning any unwanted RF to plug ground, am I correct? This would also differ from full shielding (both end must connected)... Can you explain the major difference(s)/benefits between the 2 process?
    Thanks;
    TK
    DARE TO SOAR:
  • fbm211
    fbm211 Posts: 1,488
    Im curious about shielding and if I really need a saftey ground for my digital front end or not.I look at VH Audio DIY AC Power Cables and see that the shield is only connected at the IEC end and a saftey ground to both ends.Can you elaborate on his designs.Thank you.>>http://www.venhaus1.com/diymains.html
  • TECHNOKID
    fbm211 wrote: »
    "Flavor #1" is actually what sTiLlLeArNiNg is accomplishing with his own DIY while he connects the opposite way doesn't really matter as it eventually gets back to the wall safety ground anyway. This is what I am referring as using the shield as an antenna. This type of cable connection will be used if and only if your componet use safety ground.
    If your component doesn't require safety ground (IE: most CD/DVD players "flavor #3" would allow you to hook your shield to the house safety ground through a 3 prongs male.
    Basically, the type of cable used by your gear will dictate if #2 or #3 is appropriate, right?
    Hummm, very interesting notes on ferrite use
    Notes:
    * Try experimenting by using a ferrite clamp on the safety ground only at the load end (the end with the IEC). Many people have suggested that use of Ferrites help filter out garbage in power cords, but I have found that Ferrites constrict the dynamics of the system and they ADD inductance to the hot/neutral (rather than lower it- which is our objective). By putting the ferrite on the safety ground only, we are able to attenuate any unwanted nasties that try to make it into the component via the ground. (you don't need to do this tweak with "Flavor #3", because the ground is not coupled to the component)
    * If you have the experience, and want to "trick out" your AC even more, I would suggest going to Magnan's site and read tweak #2: "Do-it yourself approach to AC line filtering". Lots of good stuff on his site. I especially like the idea of using ferrite toroids on other AC cords around the house to keep garbage from being dumped into the lines!
    I really like their easy to follow step by step instruction, makes it for a flawless project :cool:
    Cheers!
    TK
    DARE TO SOAR:
  • TouchOfEvil
    TouchOfEvil Posts: 967
    very nice work.
    Living Room Rig:D
    Rotel RSP-1069/Rotel RMB-1095/Rotel-1072/Polk lsI15's W/modded xoverW/DBsubs/Polk LsiC/lsI7's/Klipsch sub-12"the weak link"/DLP Mitsubishi 65"
    Xbox360/PS3/WII
    M.Br. setup:)
    Emotiva MMC-1/Rotel RMB-1075/Polk BlackStone TL350's/Velodyne SPL1000/Samsung 51" Plasma
    Computer Rig:
    Rotel RB1050/Tannoy DC4's/Klipsch RW-10d/ImodIpod/HK AVR230 for now....
    Headphones-Ultrasone-HFI780's w/LittleDot MK Vamp Portables Panasonic HJE-900's
  • sTiLlLeArNiNg
    First i'd like to say that i REALLLY REALLY suck at explaining stuff, that is why i posted only pic's in my first post but i'll try my best :o
    Doing lil' project's like these are always fun IMO and i look forward to doing more as time goes on :) I don't think i came across the "Bob Crump" cable build TBH?
    My gear only has 2 pin male IEC (equipment side) so in my case it made no sense to go with the 3 conductor wire OR to connect the shield to a dead pin on that end, that's why i went with 2 conductor and ran the shield out through the ground pin on the socket. Maybe there would be a benefit to connecting the shield on the opposite end i don't know :o The idea is to "catch" the "dirty" EMI/RFI signal's and get them away from the wire's that are directly connected to the equipment :o
    I thought I had already posted but my source but i'll post again everything was sourced from TakeFiveAudio here in Ontario, Canada :D
    disneyjoe7 wrote: »
    Please read my first reply :)
    TECHNOKID wrote: »
    Thanks;
    TK
    I cannont comment on the first part of your post TK as i am really not knowledgeable enough to do so, it may be beneficial but honestly i think using something similar to what i have used here will work well enough for audio application. You being an electrical engineer/tech would know MUCH MUCH more than me ;)I'm pretty shure the military application is more concerned with full/total shielding as the use's are more critical.
    For the second part of your post yes the goal is to have the shielding on the cable act as an antennae and draw the EFI/RFI out and send them out through the ground pin on the male end and into the wall. To be completely honest i am not an electrical engineer and i could not fully answer this part of your question but if you read part of my first reply in this post you will see why i chose to go with this method in MY application. To clarify the Belden cable i used has a 100% coverage mylar foil shield and an 85% coverage braided shield plus the teflon casing so IMHO it is quite good, if it was in 10g i think it would be that much better :o
    Hey TK what are your thought's on cryogenically treated component's? I beleive the theory behind it :o It's supposed to demagnitize the metal and improve overall charecteristic's IIRC :confused:
    fbm211 wrote: »
    As i previously mentioned a couple time's i am not an electrical engineer or electrician, i am simply an enthusiast with a great interest for DIY project's and a lot of tool's/spare time lol So i like to try and keep buisy :) Sorry i can not elaborate any more than i have already :o
    To be honest i took my inspiration from the project's posted at VH audio, same link you posted ;) I read through them and a few other post's on the web concerning/regarding wire's/cable's. I also got some good info on cable's from our fello Polkie DarqueKnight :) I then proceeded to contact the local DIY supplier and got confirmation on what i wanted to do and needed to complete the job, ordered up the part's and voila! :)
    very nice work.
    Thank you :)
    Here is another link with some good info about cable theory/charecteristic's/properties whatever you want to call it http://www.audioquest.com/pdfs/aq_cable_theory.pdf Big thank's goes out to DarqueKnight for the helping word's and link to the audioquest .pdf :D
    Media Room 7.1
    HTPC
